Old Sat, Apr-21-2012, 04:40:15 PM   #11
EricSMG
30 something
Default Re: WARNING: RE RSM's and Koni 1159S not compatible!
Originally Posted by white-hot View Post
Rogue offers 12mm washers for the mounts to handle the larger diameter shocks..
Interesting - so the RE mounts are able to be used with conventional shocks and the beefier units, just by swapping washers? Pretty cool.
I take it these P-shocks have the smaller 10mm shaft, hence your comment about using "your old" mounts??
Get this stuff installed already!! I need to order my new setup and I'm dying to hear your review
I think I'm just going with TCKs, though.
'04 46M 6MT || '01 330Ci 5MT
Old Sat, Apr-21-2012, 05:00:22 PM   #12
white-hot
has left the building
white-hot's Avatar
No, they have the 12mm shaft, same as the TCK's. I will use the same 12mm washers on the JT Design mounts. They are rather similar overall. Yeah, my main goal was cost and am having to pay for it with added time getting it all working. Still, for a $120 less, and IF they work well, I will be happy.
Old Sat, Apr-21-2012, 08:30:39 PM   #13
Richardsperry
95 SC M3
Richardsperry's Avatar
You have a pic of the entire shock?
Old Tue, Apr-24-2012, 02:12:07 AM   #14
mzeed
Reputation: 0 mzeed is on a distinguished road
This is mismounted>>>take it apart!!!!!!
Jump to top mzeed is offline   Reply With Quote
Old Tue, Apr-24-2012, 03:54:14 AM   #15
MMMGP
Marty
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
You're wrong. This is the image from the RE website.
Jump to top MMMGP is offline   Reply With Quote
Old Tue, Apr-24-2012, 04:06:50 AM   #16
Old Tue, Apr-24-2012, 04:37:39 AM   #17
Apexi7
Apexi7's Avatar
Reputation: 0 Apexi7 is on a distinguished road
Makes sense so the nuts don't rip threw the tower as most know. Wish I new earlier. One complete failure and one saved just in time. Definitely cant be ignored. Also have your e36 lower front subframe checked too as mine failed at the same time. Replaced mine with 99 M3 vert. e36 lower front subframe w/ Reinforcement, 3 step kbs and a coat of rustoleum for good measure. Definite over kill but than safer sorry. And now on to the diff mounts.
Jump to top Apexi7 is offline   Reply With Quote
Old Tue, Apr-24-2012, 04:56:16 AM   #18
OahuMPower
:FACEPALM:
OahuMPower's Avatar
I just installed a set of those shocks with a set of RE RSMs..
just remove the metal "housing" and continue with the install.. easy day.. just like any other Koni install
not sure why those shocks come with that retarded cover
Old Tue, Apr-24-2012, 10:39:26 AM   #19
Richardsperry
95 SC M3
They came with the cover because it's a P-car, and doesn't have the bumpstop/sleeve like the E36.
Old Tue, Apr-24-2012, 02:14:04 PM   #20
white-hot
white-hot's Avatar
Yeah, the cover is HUGE. I do have the other mounts, so it will be all good. Really like the RE units though...
Why would I not want a cover for a DD car? Would it not allow excess dirt and road crud to on the shaft and possibly shorten the life of the top seal? I know some gets in there anyway, but this would seem to limit it greatly.
The Koni's come complete with bumpstop and the cover. I will put up a pic of the whole shock when I get home tonight.
Discussing WARNING: RE RSM's and Koni 1159S not compatible! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
