Old Thu, Apr-26-2012, 08:05:26 PM   #1
tripleblackrag
AA C38-92 Renegade @ 15 psi + Nitrous
tripleblackrag's Avatar
Reputation: 0 tripleblackrag is on a distinguished road
Default AA upgrade for Rotrex to HKS style Green Filter
Here are the parts I purchased from AA to effectively remove the "Snail" , MAF and K&N to mount the filter directly to the Rotrex SC. Not shown is the ram air pipe with Temperature sensor relocation, which you will also need. I built my own Ram Air but don't feel like getting flamed over it so will leave pictures out for now. I will also most likely just end up buying the AA piece anyway when I order other parts from them.
Here's what you need:
1) Green Filter (From Gen 6 / 7 )
2) Filter adapter for the Rotrex
3) 3.5" Ram Air Pipe w/ temp sensor
4) Gen 7 SMG reservoir if applicable. I love this piece, very nice design and far better than the old power steering reservoir style.
I also added a 42 Design Ultimate catch can. I noticed oil on the silicone hoses and inlet of the SC on the old set-up and decided this was a must have. The integrated dip stick is a very useful feature as well.
Back to the topic... AA's testing has shown virtually no HP loss with the use of the Green filter as opposed to the "old" set-up. That snail is called just that not only because it looks like one, but it also makes your car slower as that complete set-up is a restriction. Not to mention the filter on the pipe problem that has been noted in many forums. Suck on a straw and you can figure it out. The longer it is the worse!
Call AA for for updated pricing on these parts.
Jump to top tripleblackrag is offline   Reply With Quote
Old Thu, Apr-26-2012, 08:07:57 PM   #2
tripleblackrag
Default Re: AA upgrade for Rotrex to HKS style Green Filter
Here it is all installed along with the catch can.
Old Fri, Apr-27-2012, 12:33:44 AM   #3
VALSBM3
AwwwYeah!
VALSBM3's Avatar
Reputation: 0 VALSBM3 is on a distinguished road
I believe the whole point of the "snail" was for the charger to be sucking in cold air. Putting a filter in the engine bay like that, I would be concerned about heat.
2002 M3 | ESS VT1-455 | BW Race Exhaust | Hawk Pads | Ground Control Suspension | Whiteline Swaybars
Custom Roll Bar | Stripped Interior | Bride | G-Force | SneedSpeed Adjustable Rear Wing | Front Splitter
SneedSpeed Brake Cooling Ducts | D-Force LTW5 Wheels/Hoosier R6 | OEM Rear Square Setup w/ Nitto NT01
Jump to top VALSBM3 is offline   Reply With Quote
Old Fri, Apr-27-2012, 01:06:28 AM   #4
MSpeedAddict
lol stock
MSpeedAddict's Avatar
Reputation: 0 MSpeedAddict is on a distinguished road
I believe that they dyno tested the difference between ram air and cold air and like pretty much all other f/I tuners they noted that the intercooler eliminates any differences between the two.
The ram air setup produces less lag and better throttle response. (same hp)
Jump to top MSpeedAddict is offline   Reply With Quote
Old Fri, Apr-27-2012, 02:16:37 AM   #5
tripleblackrag
Not to mention the cooling effects of methanol injection.
Old Fri, Apr-27-2012, 03:03:13 AM   #6
gixxer
gixxer's Avatar
Reputation: 0 gixxer is on a distinguished road
Nicely done. I may go this route someday.
need2buy: LTW flywheel + clutch ;
wish: HPF ;
Mod Journal
Jump to top gixxer is offline   Reply With Quote
Old Fri, Apr-27-2012, 03:31:56 AM   #7
tripleblackrag
I don't want to get into endless debates about which is better. If you are happy with your set-ups don't change them. Here is an option for those of us that like to change it up. This mod coupled with a Gen 7 intake manifold would be even better.
Old Fri, Apr-27-2012, 03:34:00 AM   #8
tripleblackrag
Thanks! I'd like to chat with you about your nitrous set-up as I have a kit that I want to add on to my set-up. I have a thread opened that isn't getting much action on the subject. You seem to have done it with no problems.
Old Fri, Apr-27-2012, 03:44:39 AM   #9
gixxer
gixxer's Avatar
No problem. The shop did most of the work (installations), but i can share with you the design (eg. nozzle placement) and the implementation. FYI, i'm shooting 75 (although 100 is on the horizon, but nothing more), and using MS 109, and don't have a separate fuel cell.
wish: HPF ;
Mod Journal
Old Fri, Apr-27-2012, 10:22:38 AM   #10
tripleblackrag
Great! In terms of the install, I can put it all in myself without much concern.
I would like to know key things, like where your nozzle is (as you stated), jet sizing, are you controlling injection start via a boost switch or rpm, what RPM you cut-off and if you are running meth as well.
Are you also running an intercooler spray bar?
Discussing AA upgrade for Rotrex to HKS style Green Filter in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
