Old Fri, May-04-2012, 06:25:38 PM   #1
EmDeeAr
EmDeeAr's Avatar
Reputation: 0 EmDeeAr is on a distinguished road
Default Window Rubber
Cowl DIY added!
Here:
Here are the part numbers for the cowl. Keep in mind, these are for a sedan, but you get the idea. #8 (make sure to get both a left AND a right one) here: http://realoem.com/bmw/showparts.do?...59&hg=51&fg=20
I went ahead and got new clamps and grommets (#s 12 and 13) too, just so that everything is new and fresh. I'd recommend doing this.
The install is pretty straightforward and easy:
***Note: the hood will need to be open for this to be done. It does NOT need to be put into what I have read as the "service position".
1. Take off windshield wiper caps and unscrew bolts
2. Take off wipers
3. Unclip the old rubber sealing (I cut mine to make it easier.)
4. Take out the old grommets (Don't put the new ones in yet!)
5. Clean and dry the area that the trim normally covers
6. Put in the new grommets
7. Put the new clamps on the trim
8. Slide the trim pieces on and clip them into place
I hope this clears everything up!
--I still have not figured out how to go about fixing the rear windshield seals. The rear glass almost certainly has to be removed. If anyone knows where/how to get this done, post it up!
-Michael
Jump to top EmDeeAr is offline   Reply With Quote
Old Fri, May-04-2012, 06:53:03 PM   #2
jayjaya29
Photographer
jayjaya29's Avatar
Default Re: Window Rubber
The front cowl replacement only requires the wiper arms to be removed and the hood placed into the service position.
P/N: 51 71 1 977 677
Threads:
http://www.m3forum.net/m3forum/showthread.php?t=294508
http://forums.bimmerforums.com/forum....php?t=1475625
http://jlanephoto.smugmug.com/
Old Fri, May-04-2012, 07:01:21 PM   #3
The rear window can be done without removal, but it is difficult and doesn't always grab (will pop out).
The front glass must be removed to replace the windshield seal.
Only use OEM regardless of what the installer tells you.
Old Fri, May-04-2012, 07:17:09 PM   #4
EmDeeAr
EmDeeAr's Avatar
Hm well I'm hearing two different things, so let me grab a few pics. Thanks for the quick help.
-Michael
Old Fri, May-04-2012, 07:41:44 PM   #5
The cowl can be done without removing the glass. When you say "around my two windshields" that says the windshield seals.
Old Fri, May-04-2012, 11:06:14 PM   #6
EmDeeAr
EmDeeAr's Avatar
Yeah I feel you. The windshield seal in the rear definitely needs to be replaced, and at least the cowl up front as well. The seal up front might need it, but I need to check that. I'll update you guys tomorrow.
-Michael
Old Sat, May-05-2012, 01:16:27 AM   #7
cscat87
cscat87's Avatar
Reputation: 0 cscat87 is on a distinguished road
I just did the rear one on mine, it was pretty easy. Getting ready to do the cowl soon.
03 M3 Convertible 6-spd- Alpine White/Cinnamon
97 M3 Coupe 5-spd- Cosmos/Black
Jump to top cscat87 is offline   Reply With Quote
Old Sat, May-05-2012, 11:23:16 AM   #8
hencini
Carlos is My Co-Pilot
hencini's Avatar
The little corner pieces on my rear window are destroyed, but everything else seems fine.
Jump to top hencini is online now   Reply With Quote
Old Sat, May-05-2012, 01:59:40 PM   #9
scoobiedoo2029
Reputation: 0 scoobiedoo2029 is on a distinguished road
same my passenger side top corner piece is completely gone. the safelight glass guy that lives down the street says to get all the gaskets and pull the rear windshield....
i havent done to much reading on it yet i couldnt find the part number on realoem to figure out what i can buy to replace.
Jump to top scoobiedoo2029 is offline   Reply With Quote
Old Sat, May-05-2012, 02:09:09 PM   #10
EmDeeAr
EmDeeAr's Avatar
Seems like a lot of us have this same issue. I'll try to do some research today to see what's up. I'll report back with where to buy the parts and how to get them installed.
-Michael
Discussing Window Rubber in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
