Old Sat, May-12-2012, 01:37:40 AM   #1
coolkev
coolkev's Avatar
Reputation: 0 coolkev is on a distinguished road
Default Vf stage 2 tial bov+boost gauge vacume line routing
Hey guys im having trouble on routing the vacume lines for my tial bov and boost gauge. I have already looked at the other diy threads on the bov mod and still cant figure it out. Upon startup the eml light came on and my boost gauge was reading 16lbs of boost? If anyone can help i would appreciate it .
Jump to top coolkev is offline   Reply With Quote
Old Sat, May-12-2012, 02:15:52 AM   #2
ej205gdb
ESS S/C ///M
ej205gdb's Avatar
Reputation: 0 ej205gdb is on a distinguished road
Default Re: Vf stage 2 tial bov+boost gauge vacume line routing
what line did you tap?
Jump to top ej205gdb is offline   Reply With Quote
Old Sat, May-12-2012, 04:41:48 AM   #3
coolkev
coolkev's Avatar
I tapped into the line coming from where the fuel rail is.
Old Sat, May-12-2012, 11:26:21 AM   #4
VALSBM3
AwwwYeah!
VALSBM3's Avatar
Reputation: 0 VALSBM3 is on a distinguished road
You might have a vacuum leak somewhere. I would recheck your lines. Also, you may want to try tapping your gauge into the booster line, before the check valve.
2002 M3 | ESS VT1-455 | BW Race Exhaust | Hawk Pads | Ground Control Suspension | Whiteline Swaybars
Custom Roll Bar | Stripped Interior | Bride | G-Force | SneedSpeed Adjustable Rear Wing | Front Splitter
SneedSpeed Brake Cooling Ducts | D-Force LTW5 Wheels/Hoosier R6 | OEM Rear Square Setup w/ Nitto NT01
Jump to top VALSBM3 is offline   Reply With Quote
Old Tue, May-15-2012, 01:40:18 PM   #5
coolkev
coolkev's Avatar
Hey guys found my problem one of the throttle body clamps was in the way of the throttle linkage not allowing the throttle bodies open all the way
Discussing Vf stage 2 tial bov+boost gauge vacume line routing in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
