Old Sun, May-13-2012, 11:21:51 PM   #31
whips333
whips333's Avatar
Default Re: Permanent vanos hub fix not so permanent
Originally Posted by whips333 View Post
To the OP...are these Dr. Vanished hubs or your own modified hubs?
Sorry I meant Dr. Vanos.
Jump to top whips333 is online now   Reply With Quote
Old Sun, May-13-2012, 11:30:21 PM   #32
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
they're his modified hubs, not Dr Vanos' cryo hub
Old Sun, May-13-2012, 11:45:00 PM   #33
turbotoy2791
CNC C300 Maraging Vanos Hub
turbotoy2791's Avatar
Reputation: 0 turbotoy2791 is on a distinguished road
Originally Posted by thestigCLT View Post
Something is definitely not right here. In Post #16 it appears the failure region has a cup like shape in the hub and has a mostly brittle fracture mode I have a hard time understanding why this tab failed this like or at all for that matter. It might be that the part requires more ductility than strength.
Going to 4340 with such a high yield strength (186 ksi) is going to make the material even more brittle especially in the presence of any stress concentrations. I recall that these materials can be very susceptible to cracking due to certain sealants or lubricants, moly difsulfide comes to mind.
Just for reference:
Metals Handbook, Volume 1, Properties and Selection: Irons, Steels, and High-Performance Alloys, p. 195 – 199, 430 – 448, and 609, ASM International, Tenth Edition, 1990.
http://www.asminternational.org/cont...81G_Sample.pdf
Well they make connecting rods and cranks from 4340, sealants and lubricants should not be a problem.
If only Nikola Tesla was still alive he could give us some insight.
I have a few guys I need to talk to about this one is a gear maker and the other works at a heat treating shop. It will be Tuesday before I have more information.
I am going to try the 4340 see how long it last if it makes it past 50000 miles it will be acceptable to me since when the tabs fail they do not escape and fall in the engine. If it does not make it to 50000 I will take the pump out of the engine and use an external hydraulic pump ran off a belt for the vanos.
I could also tighten up tolerances between the pump and hub but, If they are not in perfect alignment this may also cause a problem, it may work in one engine but in another it may bind and cause the pump bearing to fail. I don't know how close this alignment is from car to car.
They are other ways to fix this buy putting some kind of absorber in the pump or on the hub. As you ad parts you have more to fail and more to wind up in the timing chain.
Jump to top turbotoy2791 is offline   Reply With Quote
Old Mon, May-14-2012, 12:39:11 AM   #34
thestigCLT
Reputation: 0 thestigCLT is on a distinguished road
Thanks for the paper. What's bothersome to me is the how the tabs failed. There are no signs of fatigue at least not that I can see at least on one tab. The other tab might have some ductile tears. Just very surprising especially after seeing your hammer test. Oh and are connecting rods made of extremely high strength 4340?
2002 M3 Steel Grey, 18" Fikse Profil10 (235/40F-8.5" 38ET, 265/35R-10" 32ET), Michelin PSS, KW2, Eisenmann 83mm, Umnitza Orion V2 (6000K) AE, RE RSM, PF RTABs, Painted Reflectors, Hardwired V1, Rotex Gold Brake Pads
Jump to top thestigCLT is offline   Reply With Quote
Old Mon, May-14-2012, 01:01:28 AM   #35
Reputation: 0 Obioban has a spectacular aura about
Interestingly, other BMW engines don't have the loose tolerance between the hub and pump... At least the M54 and s50b32. I wish we knew the reason they felt the need to add the slop on the s54.
I wonder if there's some SLIGHT cam shaft slop at 8000rpm that they were trying to allow for.
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Old Mon, May-14-2012, 01:33:49 AM   #36
CybrSlydr
CybrSlydr's Avatar
Reputation: 0 CybrSlydr is on a distinguished road
I'm subbing to see what happens - this is quite surprising!
Turbo doing this like he has makes me feel a lot better about buying a hub from him if/when I ever need one.
Jump to top CybrSlydr is offline   Reply With Quote
Old Mon, May-14-2012, 02:23:11 AM   #37
MahCBCNe46
Reputation: 0 MahCBCNe46 is on a distinguished road
Aww man this sucks
Jump to top MahCBCNe46 is online now   Reply With Quote
Old Mon, May-14-2012, 03:21:55 AM   #38
MahCBCNe46
Originally Posted by SYT_Shadow View Post
Hi everyone,
It was my hub which broke. The engine is still operable, although the tabs fell inside so I'll have to fish them out.
I put 15k on them. Hard driving, but I did not track the car.
Yesterday I did a DIY of how to remove the entire vanos, valve cover, etc (so you all can update your bolts and check on your tabs) and when I removed the vanos they were both gone.
The welds were inmaculate... the tabs were ripped clean off.
I expected the oil pump to be seized causing the hub failure, but it was perfectly fine and spins around very well.
SYT
Did the tabs fall into your engine while you were taking them out? or did they fall in there by themselves when they sheared?
Where you taking the engine apart because of the broken tabs (SES light?) or just found them in the process of just making that DIY?
Old Mon, May-14-2012, 03:30:12 AM   #39
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
A great thing about Turbo's design is that it's not possible for the tabs to fall into the engine. They fell in when I separated the vanos assembly from the engine. I heard a ticking sound when they fell and didn't understand what had happened until I saw the missing tabs.
I took my engine apart because I was doing a DIY for the forum. I did have a SES light but was convinced it was a dirty vanos actuator or the solenoid.
Had I not been doing the DIY I would have replaced the solenoid and the vanos actuator with a brand new unit that just arrived and found that the problem was still there.
I'm going to have to dismount the oil pan to get the tabs out... I'm not looking forward to it
Old Mon, May-14-2012, 03:37:11 AM   #40
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Originally Posted by deadlysyns View Post
Wow, that took alot of force to sear both tabs off.
Scott,
Have you considered trying to do a 4 tab design instead of two? This would require drilling two extra holes on the pump though. We all can learn something from this and try to pin point why the tabs are breaking off. I am curious if one tab broke off first then the 2nd tab broke off.
Also on the 4340 material, you may have this metal austenitized, oil quenched, and tempered at 850°F per AMS-H-6875 to get a high strength part.
My thoughts exactly... with 4 holes and 4340 that thing should be indestructible.
Discussing Permanent vanos hub fix not so permanent in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
