#41 | |
![]() Location: Connecticut
For the ears, I meant by driving and listening.
![]() 1998 M3/4/5 v3 S/C'ed -- SOLD 9/14/12 |
#42 | |
Craig
45 degrees is an eighth etc... A better way is to actually measure, with a ruler how much play you get at the outer edge of the drive shaft. Marke it with a grease pencil or scribe, or something then hold the ruler to that mark and roll the drive shaft. You should be able to tell by looking if the play is in the u-joint, or further into the differential. Let's all hope it is the U-Joint and not a poorly installed pinion.
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ |
#43 |
:FACEPALM:
![]() Location: San Diego
huh.. what?!?!?!?! can u please explain in simple explanations.. trying to read your responses is killing me
#44 |
Craig
Mine or OP's?
