Old Wed, May-23-2012, 01:05:52 AM   #1
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Reputation: 0 pawa_k2001 is on a distinguished road
Ukraine
Default Track day brake problem
I came back from CMP this past friday. I am running PFC 06 pads front and rear and Motul 5.1 fluid. My brakes start getting spongey in the middle of the session. Coming back home, my brakes would only start working near the end of the pedal travel. Even after the brakes cooled down the pedal felt very mushy and work only at the end of its travel.(I was driving from CMP to Asheville which is 3.5 hours) Also, the brakes were making a metal to metal grinding noise.
I drove the car next day and brake pedal felt good. Also, the grinding noise disappeared. The only issue now is that I have warped rotors.
I have another track day at VIR on June 9th/10th. Trying to resolve my braking issue before then.
Suspension: AST 4100 GTS Suspension, Vorshlag camber plates, Reinforced rear subframe, Powerflex bushings
Engine: Stock
Brakes: Bimmerworld Brake Stiffener Kit
Interior: Jaffster Delrin Shifter Knob
Wheels: Apex ARC-8 18x9.5" W/ Dunlop Star Spec tires 275/35/18
Jump to top pawa_k2001 is offline   Reply With Quote
Old Wed, May-23-2012, 01:12:02 AM   #2
cash7c3
y so srs?
Reputation: 0 cash7c3 has disabled reputation
Default Re: Track day brake problem
have you bled them? Motul 5.1 on big heavy car run something with higher boiling points
Jump to top cash7c3 is offline   Reply With Quote
Old Wed, May-23-2012, 01:19:20 AM   #3
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
I bled them after the track day. Should I run some ATE blue fluid?(I got a couple of bottle of them at home) Also, what could have been that grinding noise? I pulled over to check if there was anything metal on metal but the pads were good. Only the second track day on them.
Engine: Stock
Old Wed, May-23-2012, 01:24:08 AM   #4
cash7c3
y so srs?
spongy brakes is probably fluid/brakes getting too hot. long pedal travel is probably air in the system if you bled them and then pedal travel was normal afterwards. or perhaps some combination of both . I prefer motul rbf600, ate super blue is similar (slightly lower boiling points), it's personal preference between those two options.
I would guess the grinding would be some pad deposits that have since worn off.
edit, just noticed the warped rotors bit. you sure? that is likely pad deposit that will eventually wear off.
Old Wed, May-23-2012, 01:32:01 AM   #5
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
Thanks. I will flush my brakes with the ATE blue and get some new front rotors. BTW, what is a good front rotor? Price and performance.
Engine: Stock
Old Wed, May-23-2012, 01:35:05 AM   #6
Zoomz
Vroom.. Vroom.....
Zoomz's Avatar
Reputation: 0 Zoomz is on a distinguished road
That 5.1 is not ment for high temps (on track)
Ditch it and use the superblue. Make sure you start the bleeding on the pass rear, then the other rear. Then pass front and finish with drivers front.
Good luck with that
Far from stock
Jump to top Zoomz is offline   Reply With Quote
Old Wed, May-23-2012, 01:35:59 AM   #7
cash7c3
y so srs?
couldn't help you there, have comp package on the e46 and the track beater is so light stockers are plenty. regarding the warped rotors bit read my edit above.
and http://www.zeckhausen.com/avoiding_brake_judder.htm
Old Wed, May-23-2012, 01:40:19 AM   #8
Zoomz
Vroom.. Vroom.....
Zoomz's Avatar
Tire rack has decent price on plain rotors. Or I like to use topbrakes .com
Also http://www.zeckhausen.com/ on the sponsors page.
He is a great guy with just as good service, and generally always has stock ready to ship.
Far from stock
Old Wed, May-23-2012, 01:41:45 AM   #9
Zoomz
Vroom.. Vroom.....
Zoomz's Avatar
Lol both linked Dave Z's site.
Far from stock
Old Wed, May-23-2012, 01:42:51 AM   #10
cash7c3
y so srs?
it's where i get all my pads
Discussing Track day brake problem in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
