#41 | |
"Visor down for business"
![]() Location: Little Rock, AR
Great feedback and advice bud, thanks though, fwiw, I have TCK D/A's with Vorshlag plates and I've recently developed spring binding at slow speeds over road humps. At this point, I really don't want to do something too drastic (buy, install spring thrust kit), rather clean and lube components of the plates and springs. I'll update the thread if this works and removes the noise; btw, what was the torque spec on the top shaft nut? Thanks
#42 |
30 something
![]() Location: San Diego
Forget hand torquing the top nut. Vorshlag recommends using air tools for the top nut, as do I. Always have, always will, always works perfect. This allows a snug fit without overtorquing since the strut shaft spins.
I'm still having zero noises or issues with my Vshlag plates, by the way. I did just install 300/400 springs (replaced my 450/500) and the car is leaps and bounds better on the street, both in comfort and handling. Now the chassis doesn't move around as much - the suspension actually aborbs the hits, allowing me to focus on the road and driving. If anything, I'd go even softer on the front, for even better "balance."
'04 46M 6MT || '01 330Ci 5MT Last edited by EricSMG; Sun, Jun-03-2012 at 03:42:16 PM. |
#43 |
^ Noted, thanks.... always fun to get out the air tools
![]() You reckon this would solve my problem?
#44 | |
+1 on using air tools on the top nut and no noise for me either with Vorshlag plates.
Do you wish that Double VANOS never existed? Vote! 2004 Silver Gray/Black M3 Convertible Last edited by maveric23; Sun, Jun-03-2012 at 04:00:55 PM. |
#45 | |
30 something
As for you problem - sounds like the Vorshlag spring perch bearings are not rotating freely, causing your bind. As far as I know these bearings are not serviceable. You sould take them out and inspect - should rotate easily by hand. If they do rotate easily, then you have another issue I'd think. Maybe a loose top nut like Maveric noted.
'04 46M 6MT || '01 330Ci 5MT |
#46 | |
