Old Wed, Jun-06-2012, 10:17:36 AM   #21
BevsM3
BevsM3's Avatar
Reputation: 0 BevsM3 is on a distinguished road
Default Re: High RPM Issue
Originally Posted by tripleblackrag View Post
Have you reset your adaptations since the injector switch? I doubt its a solution but may help some.
Yes, it was done with the new equiptment.
PM sent
Jump to top BevsM3 is offline   Reply With Quote
Old Wed, Jun-06-2012, 03:21:03 PM   #22
m3816
Shhh..my foot is sleepin on the gas
m3816's Avatar
Reputation: 0 m3816 is on a distinguished road
I am having similar issues, I am getting my boost and A/f gauge installed first to help with the diagnostics of what could be wrong. In my case I have a hunch that it is either the fuel pump/relay or the sparks.
my car makes normal power up to 6k and just drops in power after that but I should have more torque at 6k + than on the low end because of my set up. let me tell you it is very frustrating It feels like as though I hit fuel cut
HKS GTS8550 Stage II *SuperSprint*Aeromotive
Clutch Masters*4.10*Rogue Engineering
KW3*H&R*Ground Control*Euro rotors*SS lines
42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara
507WHP @ 8400rpm-11.2psi
**Need a Expert BMW tech in the DMV Pm Me**
Jump to top m3816 is offline   Reply With Quote
Old Fri, Jun-08-2012, 06:49:08 PM   #23
BevsM3
BevsM3's Avatar
Yup frustrating... I just dropped it off at the shop, I'll post the cause when they find it.
Old Sun, Jun-10-2012, 03:44:10 AM   #24
XSNAKE9
XSNAKE9's Avatar
Reputation: 0 XSNAKE9 has disabled reputation
Mexico
I am now experiencing this on my car now
Hopefully both our cars get fixed you fixed my last issue thx again by the way please keep me posted I have the exact issue but in second gear at 6,000 rpm
Jump to top XSNAKE9 is offline   Reply With Quote
Old Tue, Jun-12-2012, 12:08:04 AM   #25
XSNAKE9
XSNAKE9's Avatar
Mexico
Hello I just wanted to make a suggestion that seemed to really help me out. I usually would gap my m3's plugs between 0.23 to 0.25 since I supercharged my m3 I recently was told to gap them between 0.27 and 0.30 now the car gets up almost to 8k instead of 6k but still gives out Im going to try and make it between 0.30-0.35 maybe it will make a difference. I hope that kind of helps you.
Old Tue, Jun-12-2012, 11:50:19 PM   #26
m3816
m3816's Avatar
bump anyone resolve this yet, I am tackling sparks on thursday
Old Wed, Jun-13-2012, 12:37:23 AM   #27
BevsM3
BevsM3's Avatar
In the shop right now, I think my issue is the tune. I will post when I find out, hopefully a day or two.
Old Wed, Jun-13-2012, 07:33:05 AM   #28
XSNAKE9
XSNAKE9's Avatar
Mexico
Angry Re: High RPM Issue
I cant figure mine out, Does yours stutter right on 6k and sometimes just not go past 6k? I am so frustrated with it!
Old Wed, Jun-13-2012, 01:37:46 PM   #29
BevsM3
BevsM3's Avatar
No, it varies between different rpm's. Anything after 6200. When I find out the cause of mine I will post here.
Old Thu, Jun-14-2012, 03:32:38 PM   #30
m3816
m3816's Avatar
After running my boost and A/f gauge for the past two day. I have concluded that I have a small boost leak; my boost drops from 4.5lb to 1 or .5 as the WOT continues to 6k + rpm I figured I shed some light on my issue.
Discussing High RPM Issue in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
