Old Sat, Jun-02-2012, 02:21:19 PM   #1
halik
Reputation: 0 halik is on a distinguished road
Default resolved
Turned out to be a false alarm
Jump to top halik is offline   Reply With Quote
Old Sat, Jun-02-2012, 02:23:51 PM   #2
StevoTheHobo
Literally passes gas for a living
StevoTheHobo's Avatar
Reputation: 0 StevoTheHobo is on a distinguished road
Default Re: Subframe crack .... sigh
Don't bother going through BMWUSA. If they even cover it (big IF there), they'll replace it with the same flawed part. I recommend getting the TMS or HPF reinforcement plates and having the repair and reinforcement done at an independent indy shop.
2003.5 TiAg ///M3 "Betsy," Black Nappa interior
120,000 miles and counting
Stuff done so far
Intake: Macht Schnell elbow, aFe ProDry filter, RPI scoops
Engine:Denso Iridium UX024
Exhaust: Supersprint V2 Stepped headers, CPI pipe w/ 200 cell cats
Cooling: Rogue silicone coolant hoses, Updated OEM water pump
Brakes: TMS SS brake lines, CSL rotors
Suspension: Koni Sport + OEM springs, Meyle HD RSMs, OEM RTABs + TMS limiters, Rogue FCABs, TMS rear camber arms, Meyle HD front swaybar links
Drivetrain: UUC shifter
Chassis/Frame: TMS rear subframe reinforcement kit, TMS rear shock tower reinforcement plates
Exterior: Seibon CSL-style CF trunk (painted in TiAg), EurosportDesign clear front reflectors, Depo LED front corners, Khoalty projector foglights, VMR VB3 gunmetal, black side and kidney grills
Interior: Khoalty LED interior/trunk lights
Stereo: Custom Clarion navigation install
Jump to top StevoTheHobo is offline   Reply With Quote
Old Sat, Jun-02-2012, 03:46:33 PM   #3
WyattH
^ Although with a new "flawed" part he could do the structural foam..
\\\WyattH's Journal
Old Sat, Jun-02-2012, 04:05:55 PM   #4
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
I thought only the rear subframe had the tendency to crack or fracture I didn't know the front was also an issue....
Does the TMS subframe kite cover the front as well
Jump to top Sandeep1212 is online now   Reply With Quote
Old Sat, Jun-02-2012, 04:07:52 PM   #5
mentroc
Reputation: 0 mentroc is on a distinguished road
the last i heard they are warrantying the subframes case by case since the recall closed. so talk to your dealership.
Jump to top mentroc is offline   Reply With Quote
Old Sat, Jun-02-2012, 04:27:50 PM   #6
3XTreM3
V8 < I6
Reputation: 0 3XTreM3 is on a distinguished road
BMW won't stand behind your product fully and entirely doesn't care about you and the safety of everyone around you. Also don't go to your dealer, they know nothing. BMWNA will possibly offer you a small amount on the dealerships huge repair. Bottom line with BMW your sol, and it's cheaper, faster, better to fix yourself. Do it soon because once crack damage is exponential compounding to the point the car is undrivable and basically totaled. Its Unbelievable they are able to get away with this type of business practices putting people's life in jeopardy.
/// M3 TiAG
Jump to top 3XTreM3 is offline   Reply With Quote
Old Sat, Jun-02-2012, 06:24:59 PM   #7
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
There is no issue with the front subframe that BMW ever covered... Ar you sure it is just not a small non structural tear that some people have near the "battery box"
2004 Mystic Blau Imola Rot ///M3 Coupe SMG
Other Rides
73- 240z - L28 Block w e31 heads - prepping as a track toy
95- Legend Coupe - C32A5 block - totaled while parked
96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident
Jump to top Foo2rama is offline   Reply With Quote
Old Sat, Jun-02-2012, 07:01:14 PM   #8
IanB
Reputation: 0 IanB is on a distinguished road
Pretty sure they are refering to the rear subframe front right mounting.
Jump to top IanB is offline   Reply With Quote
Old Sat, Jun-02-2012, 08:18:37 PM   #9
Reputation: 0 Obioban has a spectacular aura about
BMW won't cover it, or at least I couldn't get them to.
If you do get it replaced, it'll be replaced with the vert floor, which is much more resistant to tears.
I have the vert floor going into mine right now... which I am then going to re enforce with plates and then fill with structural foam. Should be the strongest possible rear subframe configurations short of integrating it into a cage.
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Old Sun, Jun-03-2012, 10:23:19 AM   #10
OldFanatic
17 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
i think that's what the OP is referring to also
Are you certain there is another specific part number for this convertible floor??
I had heard this rumor before in speculation since it's a firmer chasis. But I had my floor done by BMW and had the part number and this seems to be the same as all replacement E46 floor sections.
http://www.realoem.com/bmw/partxref....ur=&series=E46
so if you're able to supply the part number, or have a photo taken and compare the two that would be great help.
2003 TiAg - OEM CSL WHEELS - OEM CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER - SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GROUP N MOTORMOUNTS - BW INTAKE ELBOW - CF RACE LIP - SUNROOF DELETE - 4.10 DIFF - CSL RACK
Jump to top OldFanatic is offline   Reply With Quote
Discussing Subframe crack .... sigh in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
