#11 |
Carlos is My Co-Pilot
![]() Location: Near the Tannhäuser Gate
Pics?
75 years and 350,000 miles of fun: 1998 M3/4/5 No mods, just maintenance 1983 CJ-7 No maintenance, just mods 1983 R65LS No intention of modding it, don't know how to maintain it |
#12 |
It's out of the car so I can't photograph it all together.
-Michael
#13 |
has left the building
The cause of the sag, if not the usual separation issue of the front and back parts of the door itself, is not the little metal latch on the door but the plastic catch inside the lock mechanism. I had a similar issue and fixed it buy getting a newer, better condition glovebox assembly. Not sure if some of the internal parts can still be purchased, but it is the catch and where it mounts that allows the door to droop some. Yah plastic!
#14 | |
Case closed.
-Michael
#15 | |
Toodle-oo Motherf**kers
#16 |
Can't...stop...buying parts...
![]() Location: Silicon Valley
My issue was one of these little clips on the inside where the vents mount. The good news is that it fixed the problem until I tightened things up. The bad news is that after so many months misaligned, it will probably never close straight again.
sent from my Galaxy Note
- Greg Cosmosschwarz / Terminal Grey "Rips" Amaretta 1997 ///M3 - 78K Miles |
#17 |
95 SC M3
![]() Location: Eldersburg, MD
How long have you guys been around?
Simple fix, Remove glove box See where the bolt, (the one and only bolt) goes through the glove box? Use a Dremel and make the hole slotted towards the front of the glove box so that when you reinstall the box, you can push it a bit further back, which will pull the door more closed. I', talking 1/4" maybe less... Done.
No matter where you go, there you are! |
#18 | |
Yeah, this works for some, but it didn't do much for me. I'm looking into replacing the latch catch, as I've heard that can help as well.
#19 |
I can't tell you how to fix the door, but I can tell you how to minimize the problem.
I tried fixing my '97 and gave up. I finally just put some black electrical tape on the glove box behind the door. When the door is closed, you now longer see gray but black. Black is kind of a masker of all things 'evil', as your eye just doesn't see the space anymore. Not perfect, but an easy engineered solution. |
#20 | |
-Michael
