![]() Location: Stratford, CT
Since the general consensus is that a 295/30/19 Yokohama AD08 will not fit on my 19x11 ET25 rear wheels without rubbing, and since the AD08 is not produced in a 285/30/19 (I would prefer to avoid the stretch of a 275/30/19), my question is:
Would it make more sense to run a 275/35/19 tire instead of a 275/30/19 tire if I would like to achieve as little stretch as possible, but still not rub? Would running a 35 series sidewall screw up the overall diameter of 26"? I do not think so, based on this logic: a 275/35/19 is probably close to how a 285/30/19 tire would fit, thus the taller sidewall is irrelevant due to the slight stretch on a wider rim. Is this true, and should I be able to run a 275/35/19 to achieve less stretch and closer overall diameter of 26"?
WTB: VarrsToen 1.1.2 LM Reps 19x9.5 +34 and 19x10.5 +22 in HYPER BLACK 2003.5 LSB/black M3 - 6MT - No Sunroof Engine: Carbonio carbon fiber intake, Evosport power pulleys Exhaust: SMURFM headers w/ Jet Hot ceramic coating, SuperSprint S-Pipes, SuperSprint X-Pipe (non-resonated), custom muffler delete w/ Magnaflow resonator Suspension: Bilstein PSS9 coilovers Brakes: GSG Motorsports cross drilled/slotted black rotors, StopTech Street Performance brake pads Wheels: VarrsToen 1.1.2 (19x9.5 ET20, 19x11 ET25) - Yokohama Advan AD08 (245/35/19 F, 275/30/19 R) Exterior: Seibon CSL trunk (unpainted carbon fiber), matte black kidney grilles & side gills, custom smoked OEM LED taillights, smoked corner lights & sidemarkers Interior: ZHP shift knob Factory Options: Navi, full power heated leather seats w/ lumbar support
HellaFunctional
![]() Location: So. Cal
Run 275/30, or choose a different tire.
oem csl or die
May I ask why you are running a 11in wheel?
2004 Mystic 6MT ///M3AN One Headers | Agency Power V2 | Evolve-R | Blitz Technospeed Z1 | BC Racing Coilovers | Macht Schnell | CSL
#4 |
![]() Location: fishkill / white plains
it fits perfect, slight stretch but looks great, saw it done the other day at a wheel shop.
#5 |
Care to explain why?
Wanted 10.5", but the wheel is now discontinued, so I was forced to go with the 19x11. Plenty of E46 M3's run 11" rears; some 12". Which one fits perfect - the 275/30 or 275/35?
#6 | |
MMMmmmmmm....
![]() Location: Show Me State
Go with 275/30. That's what I'm running on my Meisters, slight stretch not awful... Depending on ride height and camber and if fenders are rolled you may still have a slight rub. I do on larger bumps, but my ride height is low...
2005 ZCP Schwarz II/Imolarot 6spd ///M3 Quote:
#7 |
![]() Location: Zagreb
I have original csl wheels and run 275/35/19 michelin sport cup and with 10mm spacer I had rubing so go with 30 if possible
#8 |
Seems like no one has ever really put any thought into this topic. Any other input?
Those wheels are only 19x9.5 though. Image a wheel with an extra 1.5" width; the taller sidewall would be stretched to fit how a 275/30/19 would fit on your smaller rim. At least that would make sense to me.
#9 | |
![]() Location: Peoples Republic of California
You guys keep forgetting, not all 275s are 275s, not all 305s are 305s since that number is merely the tread with, not total width. |
