Old Sun, Jul-08-2012, 07:38:42 AM   #1
ColoM3
Reputation: 0 ColoM3 is on a distinguished road
Default Vibration when braking (60mph+) Update
Hi, have a slight problem here that just happened recently. At above 60mph when I brake (light or hard) my steering wheel vibrates/shakes. Also above 60mph the car feels "lumpy" like the the front end it not tight w/o braking. I have tried these fixes so far:
Replaced left rim (because it was vibrating w/o braking), vibrating stopped when not braking.
Replaced both front rotors(today). I'm using Stoptech pads 10k).
FCAB's were replaced 10k ago, along with Koni shocks.
About 2 months ago, the right brakes were stuck, causing the the car to driff to the right and the rotor was very hot. I let the car sat and it was fine after. Could my calipers be bad.
Do I need to "bed in" the new rotors?
Thanks in advance for any advice.
Jump to top ColoM3 is offline   Reply With Quote
Old Sun, Jul-08-2012, 08:36:17 AM   #2
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
Default Re: Vibration when braking (60mph+)
if the brake caliper was sticking before.. letting it sit isnt going to cure the problem. If only it worked like that and things would fix them selves.
Your caliper is most likely still sticking. You need to remove the calipers and try to compress them back with a small C-Clamp or big pair of Channel Locks usual works to. I Like to stick the brake pad in against the caliper when compressing so I dont damage the caliper piston but thats just me. they need to move most of the way in.. dont move em them a couple inches and say its good. Ive seen many brake calipers push in about 2 inches then stop...
If they dont move u need a re-build kit or new brake caliper(s).
05 Carbon Black/Cinnamon SMG
* Technology is the Replacement for Displacement *
Jump to top Taunto is offline   Reply With Quote
Old Thu, Jul-12-2012, 08:10:04 PM   #3
ColoM3
Update:
So, I fixed the "lumpy" and partial shudder issues. It was cupped front tires and warped front rotors. The shudder issue is still there at high speed braking just not as bad. So, I was driving today and pulled the e-brake, the shudder was very apparent. I'm thinking warped rear rotors. Could this be possible? I've driven the car a couple times and didn't realized the e-brake was on.
Old Thu, Jul-12-2012, 08:22:52 PM   #4
lmtfi
lmtfi's Avatar
Originally Posted by ColoM3 View Post
Update:
Our rotors don't warp. You might have had a pad imprint from your earlier issue - but imprints wear off.
Old Thu, Jul-12-2012, 08:27:31 PM   #5
ColoM3
I forgot to mention that I had Stoptech slotted rotors.
Old Thu, Jul-12-2012, 11:04:37 PM   #6
Jonzny
Jonzny's Avatar
Reputation: 0 Jonzny is on a distinguished road
What makes them different?
Jump to top Jonzny is online now   Reply With Quote
Old Thu, Jul-12-2012, 11:35:18 PM   #7
akashyap
akashyap's Avatar
Reputation: 0 akashyap is on a distinguished road
I have these rotors too and I get massive pad deposits idk why.....
CDV Delete, Auto Solutions 30%, Koni Yellows, Vogtland Springs, TopSpeed Exhaust
Jump to top akashyap is offline   Reply With Quote
Old Fri, Jul-13-2012, 02:34:15 PM   #8
Ilove2dubb
Ilove2dubb's Avatar
Reputation: 0 Ilove2dubb is on a distinguished road
Sounds like a warped rotor...
Jump to top Ilove2dubb is online now   Reply With Quote
Old Sun, Jul-15-2012, 02:04:58 AM   #9
nikzbord
Reputation: 0 nikzbord is on a distinguished road
There is NO such thing as a warped rotor.
Jump to top nikzbord is offline   Reply With Quote
Old Sun, Jul-15-2012, 02:14:47 AM   #10
lmtfi
lmtfi's Avatar
http://www.zeckhausen.com/avoiding_brake_judder.htm
http://www.centricparts.com/files/Ce...ake%20Disc.pdf
Discussing Vibration when braking (60mph+) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
