Old Sun, Jul-29-2012, 12:23:23 AM   #31
itsme
itsme's Avatar
Reputation: 0 itsme is on a distinguished road
China
Originally Posted by firespydar View Post
i just finished checking the O2 sensors with the computer, the lambda-sensor voltage 1 and 2 both rests at 4.75 during drive and WOT it moves to 1.1-1.6 for a couple of seconds and goes back to 4.75, the "monitor sensor 1 and 2 after cat" is consistently at 4.71...it wouldn't change until i hit about 100 mph whiles monitoring live data, then it moved to 3.12 and then back to 4.71.... for a very short second. i tried using the multi-meter but couldn't get any readings perhaps wasn't hot enough ? it takes my car about 5 to 6 cranks to start the engine when engine is cold and when it starts the idling is very rough after a short drive check engine lights up with the same four codes
202 fuel trim limit Bank 1
203 fuel trim limit Bank 2
227 fuel trim, Bank 1
228 fuel trim, Bank 2
should the oxygen sensor be affecting my start characteristics ?
You have an E36 M3 correct? How do you have a lambda sensor?
O2 sensors would not cause any starting issues. You mentioned that you replaced the head, how sure are you the set the VANOS timing correctly?
From the symptoms of long crank before start and you recently did some head work. I'll double check the VANOS first.
Sent from my DROID4 using Tapatalk 2
-Wing
2002.5 Stl Grey M3 SMG II
Jump to top itsme is offline   Reply With Quote
Old Sun, Jul-29-2012, 04:47:42 PM   #32
firespydar
Reputation: 0 firespydar is on a distinguished road
Default Re: Please help me diagnose my car
i used lambda and o2 sensor interchangeably, i am sure the vanos timing was set right, i have done it on three different occasion with no problems, i could probably redo it all over again, the car runs great when the engine is warm, and no start issues when its warm. i will look into the vanos setting again. thanks for your help
Jump to top firespydar is offline   Reply With Quote
Discussing Please help me diagnose my car in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
