Old Sat, Jul-21-2012, 10:02:46 PM   #1
aeronaut
Reputation: 0 aeronaut is on a distinguished road
Question RTABs, OEM style, which?
Gotta order a few parts to finish suspension, so I'm going ahead and consolidating an order for a few other things needed, including RTABs. Going OEM style. Couldn't find an opinion/info on here on which of the following is best, or does it matter:
-Genuine BMW
-Lemforder
-Meyle "heavy duty"
Only $5 total difference between all 3, just want to use the best.
Opinions?
Jump to top aeronaut is offline   Reply With Quote
Old Sun, Jul-22-2012, 12:08:44 AM   #2
aeronaut
Default Re: RTABs, OEM style, which?
Hmmm...now it looks like my 95 RTABs are different than others? At least according to OEM #'s. A bit confusing.
Old Sun, Jul-22-2012, 12:23:33 AM   #3
ed007
ed007's Avatar
Reputation: 0 ed007 is on a distinguished road
If I remember correctly, Lemforder RTAB's are OEM. I did them on my car two months ago, and they are PITA to replace. Gotta get alignment too after you are done.
Jump to top ed007 is offline   Reply With Quote
Old Sun, Jul-22-2012, 12:32:48 AM   #4
aeronaut
That's what I understand too. Now trying to understand why Pelican lists RTAB's for 95 only, and 96 on. Would also like to know what's 'heavy duty' about the Meyle's.
Old Sun, Jul-22-2012, 12:59:02 AM   #5
SKyle
SKyle's Avatar
Reputation: 0 SKyle is on a distinguished road
Can't go wrong with Lemforders
Jump to top SKyle is online now   Reply With Quote
Old Sun, Jul-22-2012, 01:59:20 AM   #6
white-hot
has left the building
white-hot's Avatar
^This. If you can get lemmies always do so. They are generally the best quality in most things if you are going with an OEM-type part. I did the RTAB's in both cars recently, not too bad if you use the right tools, which is either a real RTAB tool or the ball joint press from Advance. I had a problem getting the RTAB tool so used the press and it worked fine but was a little fiddly. Also, by the limiters. RMeuropean has them for like $20. Don't pay the $40-50-60 from some places, they are just plastic discs, nothing special.
Old Sun, Jul-22-2012, 02:39:17 AM   #7
aeronaut
Pelican has the limiters for $20 too.
Still trying to figure out why Pelican lists 95 limiters different that others.
95, part number: 33-32-6-770-786-M69
"superseded' for 95, part number: 33-32-6-770-817-M69, if I go by what's on rogue engineering page.
Then, Turner says to use these, as they are most up to date: 33322228153G
ECS says to use part number 33326770786, which is the same as Pelican for the 95.
And ECS definately shows a different part number for 95 vs 96+
Confusing!
Old Sun, Jul-22-2012, 04:23:50 AM   #8
egebhardt
egebhardt's Avatar
Idk why anyone would use the OEM rubber or rubber of any kind. Maybe I'm missing something.
About the time you have one OEM rubber bushing slide out of place after getting the alignment done, you'll never do rubber again.
PowerFlex Polyurethane Black (softest) is so easy to pop in. You don't need a press to put them in. No additional NVH present. The limiters are inherently on the sides already. No brainer. $75 plus shipping from Bimmerworld.
98 Estoril on Dove M3/4/5 - New 3.25.12
98 Arctic on Dove M3/4/5 - Sold 3.18.13 Brandon driving it
98 Estoril on Dove M3/2/5 - Sold 8.6.12 Thy selling it
99 Estoril on Sand M3/2/5 - Sold 7.31.12 Eric driving it
98 Arctic on Dove M3/2/5 - Sold 3.10.12 Kyle driving it
96 Techno on Black M3/2/5-Sold 6.13.09 Ross totaled it
Old Sun, Jul-22-2012, 04:41:30 AM   #9
97_4dr_5spd_m3
Old College Kid
97_4dr_5spd_m3's Avatar
Reputation: 0 97_4dr_5spd_m3 is on a distinguished road
Got to agree. I went with 80A AKGs. No NVH at all, no PITA to install, and much beefier than the OE ones.
I hated scouring the searches to find what I wanted to only bump into a thread like this that made me second guess myself, but, after all of the research I went with the softest AKGs I could find....which is basically what I am going to do with the rest of the bushings as well.
E36M3 Price (fn) = $23,235.64 - .06(mileage) - 1,802.85(coupe) - 1,718.44(vert) - 442.10(age of M3)
2012-2010 Mket Price (fn) = $16,593.86 - 0.05(per mile) - 2,907.51(coupe) - 2,262.52(vert) + 16.35(age)
Sedan Price (fn) = $20,183.43 - 0.04(mileage) - 340.09(age)
Coupe Price (fn) = $22,133.90 - 0.06(per mile) - 465.11(age)
Vert Price (fn) = $31,164.49 - 0.09(per mile) - 1,019.64(age)
Jump to top 97_4dr_5spd_m3 is offline   Reply With Quote
Old Sun, Jul-22-2012, 09:12:41 AM   #10
aeronaut
I've read a lot on this topic. OE type RTAB's for me. Everytime I think of going poly for ease of install, I research again, and decide OE. For example...a Vorshlag article;
http://www.vorshlag.com/product_info...roducts_id=421
"Polyurethane is a bad choice for a bushing material if it has to deflect - such as in a multi-axis suspension bushing location like the RTAB. Rubber bushings + limiters or a complete replacement with a custom steel spherical bearing are the only two textbook choices for this location. We have seen a number of RTAB failures on BMWs that were using poly in these areas"
"If you have a street car or dual purpose BMW you should always stick with OEM bushings and RTAB limiters, and even many race prepped BMWs use this setup with excellent results."
As far as I can tell, ease of install is the only advantage of a poly bushing for this location for most uses (street, autox, etc.)
Discussing RTABs, OEM style, which? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
