Old Mon, Jul-23-2012, 07:16:21 PM   #1
Bmill160
Reputation: 0 Bmill160 is on a distinguished road
Default Hole in my Valve Cover
I was driving home from work the other day and turning into the high school where I coach on the side, and I started blowing white smoke behind me and from under the hood. I popped it out of gear and pulled over immediately and shut the motor off (smoke is never good...)
When I lifted the hood, there was oil spatter all over the inside of the engine bay. I keep my engine detailed so it was very quickly obvious where the oil was coming from. A portion of the VCG was protruding from its seat and I was assuming (and hoping) that I just blew the VCG.
I had the car towed to a local high end sports car dealer and when we took the cover off, we found a large hole had been ripped in the valve cover right above the timing chain. Has anyone seen this before or have any ideas why it would have happened?
From some reasearch, I'm seeing either VANOS hub tabs being ripped off or a similar failure. We don't know the extent of the damage yet but I wanted to reach out for advice. We've owned BMW's forever and this is my second M, but this should NOT happen...
Jump to top Bmill160 is offline   Reply With Quote
Old Mon, Jul-23-2012, 07:24:46 PM   #2
Bmill160
Default Re: Hole in my Valve Cover
Here is the picture...
Old Mon, Jul-23-2012, 07:28:05 PM   #3
Hrvat
Reputation: 0 Hrvat is on a distinguished road
Looks like your cam bolts backed out or vanos tab broke off. Hopefully you pulled over right away and your engine isn't toast
Post 50 http://m3forum.net/m3forum/showthrea...+change&page=5
Jump to top Hrvat is offline   Reply With Quote
Old Mon, Jul-23-2012, 07:32:14 PM   #4
intelone
intelone's Avatar
Reputation: 0 intelone is on a distinguished road
Cambodia
Yes sir, that's the thread right there.
6MT CB .:. IMEF IMHG OIF USMC Veteran .:. College Student
///Alpine .:. 9861 .:. H/C 701 .:. S624 .:. JL Audio .:. 300/4 300/2 500/1 .:. 10W6v2 wicked .:. Focal K2Ps
Diamond Graphite v710s .:. KW2s .:. ZCP Rotors .:. 996 Calipers .:. SS lines .:. Textar pads .:. VIS Bootlid
CSL Diffuser .:. CF Grills & Gills .:. Alcantara Steering Wheel & Boots .:. 55w 5000K TFX
My Sequential Turn Signals
Jump to top intelone is offline   Reply With Quote
Old Mon, Jul-23-2012, 08:01:48 PM   #5
Bmill160
I didn't throttle after I saw the smoke, just coasted about 100 feet to the first safe spot. It didn't throw the check engine light or sound funny or anything. I didn't even hear a bang when it happened, nothing out of the ordinary except the smoke.
An engine should not just instantaneously blow like that without warning and with proper maintenance..
I'll update as soon as I hear..
Old Mon, Jul-23-2012, 08:05:48 PM   #6
timsev
Reputation: 0 timsev is on a distinguished road
good luck man. Looks like you may have caught it in time. If so, you just dodged a bullet and you need to buy a lottery ticket.
Jump to top timsev is offline   Reply With Quote
Old Mon, Jul-23-2012, 08:12:18 PM   #7
COOKi3
Waking up a neighborhood near you
COOKi3's Avatar
Reputation: 0 COOKi3 is on a distinguished road
Armenia
Deffinitly update us and let us know if the tabs were broken. Goodluck
Jump to top COOKi3 is offline   Reply With Quote
Old Mon, Jul-23-2012, 08:17:07 PM   #8
///M3Fresh
Motorsport
///M3Fresh's Avatar
Reputation: 0 ///M3Fresh is on a distinguished road
Have either of you guys taken the VANOS or the cam gear bolts off an S54 and looked at the parts your claim to be failing?
It could be the Exhaust hub tab(s) that might have broke and cased this. I highly doubt it is the Cam gear bolts as they dont have anywhere to go. If they do I would image (when all 6 break, all at once) it would cause much more serious damage than that. Also his sproket is still in place, therefor at least once cam gear bolt in on there and the ones that broke (if any that did) are trapped behind the intake hub.
Either way OP sorry to hear this, keep us updated!
CLICK
Jump to top ///M3Fresh is offline   Reply With Quote
Old Mon, Jul-23-2012, 08:22:23 PM   #9
Firstboost
Firstboost's Avatar
Reputation: 0 Firstboost is on a distinguished road
I theorize a broken exhaust hub tab that got caught in the timing chain, caused the chain to jump/snap and hit the valve cover causing it to break.
2006 M3 ZCP Tiag AA Gen 6 ~ KWV1 ~ Custom DME w/CSL SMG ~ ST60 *CURRENT*
2001 S2000 W/F22 - Full Race GT30/J's Racing/Mugen/WORK XSA/AEM EMS 395RWHP 274TQ *SOLD*
Jump to top Firstboost is offline   Reply With Quote
Old Mon, Jul-23-2012, 08:26:32 PM   #10
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
+1,
you will probably need a another engine.
Jump to top deadlysyns is offline   Reply With Quote
Discussing Hole in my Valve Cover in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
