#11 | |
![]() Location: Birmingham
The tab design isnt great, but I still think the material should still be strong enough to withstand the ideal pressure and impact that the hub made to absorb. It must be some sort of a mechanical failure causing a very strong impact that breaks the tabs.
2003 E46 ///M SMG 1990 E30 325is
#12 | |
Piraña Powered
![]() Location: Westchester/Boston/Windham
The tab design is horrible from a engineering perspective. It's just begging to break. They should never have a 90 degree angle like that! While mechanical failure will cause the tabs to snap right off, many times it's simply cyclical loading, the pounding movement, which causes the failure. I'm quite happy with my 4340 Turbotoy hub. At least if it fails I won't have chunks of metal falling into the engine ![]()
Vanos hub / bolts DIY Oil Pan Removal DIY Foam subframe reinforcement DIY Plastics Renewal DIY Spacer DIY ESS NA Tune Review Tools: -Shim kit -Timing tool -Engine support -Grainger foam applicator gun DIY stuff -Available in the NY/MA/NH area |
#13 | |
Did turbotoy figure out the reason why the his hub failed so early? I remember there was a thread about this.
#14 | |
There is endless speculation on failure mode, but I don't find your pump alignment problem to be one of the higher odds theories. Can't PROVE you're wrong, but point this out for others that might see this thread and not look back at some other pretty serious analysis that has been done.
ADS Quote:
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
#15 | |
![]() Location: Houston/Wichita
http://www.beisansystems.com/images/bs023_large.jpg
Keep calm and learn how to drive a MT car!
#16 | |
Piraña Powered
The one I'm running now is much improved ![]()
#17 | |
Piraña Powered
Getting a brand new solenoid is relatively pointless. I got a new one which lasted only 4 months
#18 | ||
![]() Quote:
If we can find out who manufactured our hubs for BMW, maybe we can order a new design via group buy or similar.
#19 |
![]() Location: Calgary
I'm wondering if the tabs have a very sharp inside corner? If so that could start stress cracking and failure. There should be a slight inside radius, even 0.020" radius would be good. I just bought my M3 as a fix up project. Unfortunately, my list keeps getting longer and longer.
#20 |
I decided to run the Dr. Vanos hub. It's cryogenicaly treated to improve strength and hardness. It's semi proven. Chris from Dr. Vanos has been shipping these things for 2 years now with no failures reported. My car is not my dd so I'm hoping it lasts for at least as long as I own the car. I think the revised clearances between the holes and the hub alone will take care of the issues. OEM clearance is close to 1 mm. That's a lot... With the Dr.vanos machined pump that clearance is cut more than in half. Here's hoping!!!
Sent from my ADR6350 using Tapatalk 2
2005 ///M3 | PY | Black Euro Pipes | Borla | Dr. Vanos 6 MT | SSK | Helios ST | Rogue | Powerflex | Hotchkis | VMR | Hankook | ECS /// ///Valve adjustments and DME coding services performed around Charlotte, NC. PM me for details "Unsmoked bacon isn't bacon, it's just raw ham with delusions of grandeur"
| engine, parts, vanos |
