Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013)
E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm}
Old Fri, Jul-27-2012, 07:52:01 PM   #1
docrog
Reputation: 0 docrog is on a distinguished road
Default Glass mesh batteries
had the warning lights for battery dicharging overnight/low battery after a drive. tested by BMW - needed new battery. Close to US$1000.
1 what is so special about these batteries?
2.why does the car need 2 hours reprogramming from Munich?
not convinced by the plocal BMW staff answer.
Jump to top docrog is offline   Reply With Quote
Old Fri, Jul-27-2012, 08:10:57 PM   #2
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Default Re: Glass mesh batteries
BMW requires AGM batteries for all the models that use regenerative braking.
http://en.wikipedia.org/wiki/VRLA_ba...rbed_glass_mat
Email Mike@ thebmwpartstore, I'm sure he sells this battery for a lot less
Vanos hub / bolts DIY
Oil Pan Removal DIY
Foam subframe reinforcement DIY
Plastics Renewal DIY
Spacer DIY
ESS NA Tune Review
Tools:
-Shim kit -Timing tool -Engine support -Grainger foam applicator gun
DIY stuff
-Available in the NY/MA/NH area
Jump to top SYT_Shadow is online now   Reply With Quote
Old Sat, Jul-28-2012, 03:24:14 PM   #3
I think Autozone has an AGM battery also. Probably $150-$200. The ECU has to be recoded for the new battery, but this should not be more than an hour of labor at a dealer or BMW specialty shop. Free if you have a friend with a Bavarian Technic tool or similar advanced scan tool.
Discussing Glass mesh batteries in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
