Old Sat, Jul-28-2012, 08:00:00 PM   #1
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
Arrow AST 4100's & Vorshlag camber plate minor modifications
I purchased my AST4100's back in November of 2010, after selling my ground control suspension, and have been happy with them for the most part. The one thing that I was not a big fan of in the design was the adjustable sway bracket mount on the front struts, since I was never really able to keep them tight enough with the two tightening nuts on either side.
I recently noticed that the new AST's are coming with a beefier billet sway bracket, so I called up Vorshlag and decided to purchase a set to solve my issues. When they arrived I must say they are beautiful, so I was excited to install them!
When I ordered the billet brackets from Vorshlag, they did tell me that the reason mine might be coming loose was from the excess weld on the sway bracket, which prevented the tightening nut from keeping a flat seal on the bracket. I think I received one of the first few shipments of them before they realized this, and from then on they started to grind them down prior to selling.
After disassembling my front struts, I did in fact confirm that the current brackets had a lot of excess welds on them, so I decided to try grind them down and try to use my existing brackets instead.
Here you can see the excess welds on the brackets, and the marks from the nuts trying to tighten down on them.
After taking them to the machine shop and grind them down, here they are
And lastly, a comparison of the two
So I sprayed the brackets with a little black paint and decided to reinstall them.
Another issue that I noticed with the Vorschalg camber plates, which is the same issue I had with my Ground Control camber plates, is that when switching back and forth with the camber, the disk on top of the plates tends to move as well, up to 1/8" or more, making it uncertain if you are actually returning to the same previous settings.
I've been running the BMW strut tower reinforcement plates for years now, and realized that there are two holes on each side of the plate, which line up with the two small holes in the strut tower itself. I figured if I could tack the camber plate ring to the plate, and then bolt the plate to the strut tower, then everything would be solid and no more shifting around!
Here's a pic of the welded finished product.
I also instructed them to cut off a small piece of the reinforcement plate since I noticed some marks from the camber plates when sliding close to maximum camber. I also had them tack the plate in two places where it would not interfere with the camber plate sliding back and forth.
I purchased a set of stainless steel bolts to keep the reinforcement plate tight, which doesn't interfere with the OEM strut brace. You'll notice that I only can put a bolt in the outer side of each tower, since the other bolt would interfere with the camber plates when trying to achieve more camber.
Now everything should be good to go, and I'm looking forward to the next time I have to adjust my camber, lol! Well I had fun with this minor mod to my car, and just wanted to share some information in case anyone else was struggling with the same issues I was having
Old Tue, Jul-31-2012, 03:45:20 AM   #2
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
Default Re: AST 4100's & Vorshlag camber plate minor modifications
Looks good!
Jump to top Str8///Left is offline   Reply With Quote
Old Wed, Aug-01-2012, 06:27:40 PM   #3
admranger
Registered troublemaker
Nice work!
The bolts on the camber plate through the shock tower look a bit short by lack of thread engagement on the stock nuts. Maybe it's just me though...
'02 M3, Imola/Black, 6MT, CWP, PP, xenons, no sunroof, swapped ft. strut hats, Bimmerworld radiator and oil cooler, Ohlin struts/shocks, Eibach pro kit, PFC DD Rotors, PFC pads (Z or 06, depends...), Hybrid Audio Technologies Clarus speakers up front, two HAT Legatia 8's in rear deck, two big amps in the trunk for increased downforce...
'11 E90 M3, Mebourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, bone stock
Old Wed, Aug-01-2012, 10:59:27 PM   #4
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
Originally Posted by admranger View Post
Nice work!
thanks!
The 3 bolts on top of the strut tower actually have a recessed portion that sits about 1/4" below the strut bracket, so there are plenty of threads that grab. They are the OEM bolts that you run with the strut bar
Old Wed, Aug-01-2012, 11:46:26 PM   #5
kaiv
SoCal vanos/valve specialist :D
France
^this.
I've seen this stuff in person. Some great ideas! And great work ^_^
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
Old Thu, Aug-02-2012, 12:23:13 AM   #6
BlazenXLT
always money in the banana stand
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Awesome work! I have the same issue with the plates moving when adjusting camber.
Jump to top BlazenXLT is online now   Reply With Quote
Old Sun, Aug-19-2012, 09:58:42 AM   #7
sddynamix
sddynamix's Avatar
Reputation: 0 sddynamix is on a distinguished road
I just did this mod with my vorshlag plates. Thanks for the awesome ideas!
Jump to top sddynamix is offline   Reply With Quote
Old Sun, Aug-19-2012, 04:29:45 PM   #8
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
No problem! Let me know the next time you're at the Q, or stop by on 9/9
Discussing AST 4100's & Vorshlag camber plate minor modifications in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
