Old Thu, Aug-02-2012, 08:10:42 PM   #1
action135
action135's Avatar
Reputation: 0 action135 is on a distinguished road
Default Need some help
Been on here for a while now, finally needing some help from the good guys here!
Having some trouble with what I'm assuming is something fuel related. It's weird. First time I start the car in the morning, it will rev up normally, and then lose rpm and die out. After letting it sit a few seconds, can start again and it will Idle, but any throttle input given and it loses rpms again and dies. Doesn't seem like a fuel filter issue(needs replaced anyways) since it can idle. I'm kind of at a loss right now and would love some help. Gonna try to get a code reader on it tomorrow and see what comes from the CEL it's showing.
Any help is appreciated guys!
http://i20.photobucket.com/albums/b208/ashton135/IMG_0316edited.jpg
Jump to top action135 is offline   Reply With Quote
Old Thu, Aug-02-2012, 08:32:24 PM   #2
enderw88
Craig
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
Default Re: Need some help
Does this only happen when its cold, or will it work when its warmed up? Can you drive the car at speed? It seems more like a vacuum leak, but that's just a WAG.
95 BMW M3 Current Project
Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel.
To Do: Overhaul rear suspension, front suspension
Tucson, AZ
Jump to top enderw88 is offline   Reply With Quote
Old Fri, Aug-03-2012, 03:52:24 AM   #3
action135
action135's Avatar
Happens anytime, haven't let it sit at idle to warm up and try. Was choking out on the way to work before I parked it. Would stumble when I gave it any throttle other than WOT. Hopefully I can get a scanner on it tomorrow.
Old Fri, Aug-03-2012, 04:09:03 AM   #4
enderw88
Craig
enderw88's Avatar
I am betting vacuum leak. Check all of the plumbing from the air filter to the throttle body. Something is letting air in after the MAF and it is leaning out.
Tucson, AZ
Old Fri, Aug-03-2012, 04:54:08 AM   #5
action135
action135's Avatar
Well that makes sense, seeing as I replaced the starter recently. THAT was fun
Old Fri, Aug-03-2012, 05:05:52 AM   #6
enderw88
Craig
enderw88's Avatar
So, remember, the first law of troubleshooting is: start to look the last place you worked!
Tucson, AZ
Old Tue, Aug-14-2012, 11:42:09 PM   #7
action135
action135's Avatar
Well, finally got some time out of my schedule to look into my problem. Low and behold, I found that the bellows between the maf and asc was cracked where the hose on the bottom goes. Was a brand new part a few months ago when I was replacing the starter. Go figure. The hose was completely detached. I'm thinking I found my leak!
Old Wed, Aug-15-2012, 12:22:35 AM   #8
enderw88
Craig
enderw88's Avatar
Congratulations, glad you found the problem. Now go and drive!
Tucson, AZ
Discussing Need some help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
