Old Tue, Dec-18-2012, 08:39:14 PM   #1
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
Lightbulb The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Often times manufacturers will hide part numbers from us consumers, only to end up charging us an hefty markup on the same parts we can source from our favorite online vendors for a substantially lower price. As we all continue to put thousands of miles on our kits, it would be very helpful to include details on common and the often uncommon replacement parts so we're all no longer at the mercy of our favorite supercharger kit's greedy sales departments. Being that I went through the tedious process of replacing a bunch of parts on my own supercharger kit, I'll start out by posting what I have. For whoever else has replaced parts on their own, if you can please post their part numbers, details on preferred vendors, as well as the prices paid for each item, we can essentially create a great resource for our Forced Induction M3F community. I will continue to update the first post as more replies are posted so all information is consolidated in one place.
Legend:
Black text underlined items - Replacement Parts
Orange text underlined items - Maintenance items
VF Supercharger Kits:
Vortech Related:
Vortech Supercharger Oil Drain Line - $25 + shipping from Vortech.
Originally Posted by BMtroubleyou View Post
Another tip, I have had my S/C steal beaded line fail a couple times (X2). By playing around with the S/C the line with time will fold and kink and it will some how create a hole so small *from the metal line fraying and breaking to a needle size like issue, it is *almost indetectable. Lucky that i noticed little drips and spots on the ground to notice a small leak. So Instead of ordering and ordering from Vortech, I went to my local NAPA knows how and they made me a 6000 PSI internal steel line with the same size length and threads as the previous line. Took them literally less than 5 min. Its very flexable, heat resistant and VERY affordable! *I think it was like $30! No waiting nor ordering and shipping. Right near your home!! You dont have to worry about the kinks and the line when it folds! Same as previous line, fold it, tuck it, zip tie it and never worry about it again!!! And if there is no NAPA around, let me know, i will work with you in sending you one.*
Vortech Supercharger Oil - $30 + shipping from Vortech for a three pack. (I've heard this is just regular transmission fluid)
Originally Posted by R10_Telemetry View Post
Here's some additional info on the Vortech Supercharger Oil, Part Number 009035:
V-3 Supercharger Lubricant, 4-oz. Bottles and Spout Tip Cap, Set of 3 can be purchased here:
http://www.vortechsuperchargers.com/...n.php?pvk=1125
http://www.summitracing.com/parts/vor-009035
Summit racing has them for $29 and free shipping.
Vortech Supercharger Pulley - Can be sourced used from other members or directly from VFE - $100 for the 2.62" that goes on the VF570 kits
Vortech Supercharger Oil Change -
http://www.stillen.com/prodfiles/407770~inst.2.pdf
Backup link:
Originally Posted by PYRABLDR View Post
Here is my contribution to the thread:
http://www.superchargersonline.com/i...age=page&id=55
Being that VFE kits have the supercharger kits mounted on an angle, a note on oil level measurements: you measure the dipstick at the same angle the supercharger is mounted on.
It is at the exact angle that it is mounted. At the 10o'clock.
Engine Related:
Mechanical Tensioner - 1128 1 427 252 - $33 shipped from eBay
Check Valve - 0.275" OD inlet and outlet diameters for use on 7/32" vacuum tube - I used one from an 86-87 Buick Grand National, Turbo Regal, and 1987 GNX - $8 shipped from eBay
price for replacement parts from VFE:
$25 * Brake Booster check valve w/hose*
Intake Air Temperature Sensor :
Great build and fixes!!! I had my temp sensor fail not to long ago, did a quick ohm check with my multimeter and it was bad, called VF to replace it and they wanted like $50!!!!!!!!!!!!! Here is a part number for it bought on EBAY 0280130039 total of $20.50.
Belt - I'm running a 6PK2040
Spark Plugs -
Here's the part @ for the spark plugs that were supplied with my Kit: NGK DCPR9E
http://www.amazon.com/NGK-DCPR9E-Tra.../dp/B001RM38H2
I'd recommend changing them every 10k-15k mi.
Other Engine Replacement Parts -
Here's a list of prices for some other replacement parts from VFE:
$35 Manifold support bracket and bolt
$10 Idle stabilizer valve w/extension line
$120 Intake Manifold couplers (qty 6)
$35 Filter sock
T-Bolt Clamp Upgrade:
Originally Posted by darkcrash21 View Post
Decided to do a short write up on the clamp sizes I bought and worked for any VF kit for the E46 M3.
All parts are from ECSTuning and I have included the links to their site as well. And no I dont work for or have any relation to ECSTuning except for buying parts from them
Clamps for Throttle body side of the couplers. You will need 6 of them:
Clamp - Heavy Duty T-Bolt ES#3339: $4.75 ea x 6 qty = $28.50
http://www.ecstuning.com/Search/Heav...T-Bolt/ES3339/
Clamps for Manifold side of couplers. You will need 6 of them:
Clamp - Heavy Duty T-Bolt ES#3340: $4.95 ea x 6 qty = $29.70
http://www.ecstuning.com/Search/Heav...T-Bolt/ES3340/
Clamp for SC outlet side of coupler. You will need 1:
Clamp - Heavy Duty T-Bolt ES#3335: $4.95 ea x 1 qty = $4.95
http://www.ecstuning.com/Search/Heav...T-Bolt/ES3335/
Clamp for SC manifold side of coupler. You will need 1:
Clamp - Heavy Duty T-Bolt ES#3416 x 1: $4.95 ea x 1 qty = $4.95
http://www.ecstuning.com/Search/Heav...T-Bolt/ES3416/
Full thread available here:
http://m3forum.net/m3forum/showthread.php?t=394403
Originally Posted by kidrobot View Post
These sizes will vary from darkcrash but I found these to be better sizes - presented in nominal.
6 clamps throttle body side - 2.75''
6 clamps intake plenum side - 3.00''
2 clamps vortech to intake - 3.25''
Fuel Delivery Related:
3.5Bar Fuel Pressure Regulator - 13531729319 OEM 3-series FPR which came with my VFE kit
The FPR supplied with my VF570 kit was Bosch p/n 0280160597, which is interchangeable with the BMW part # 13531729319 , just cheaper to replace ($45 vs $80).
http://www.amazon.com/Bosch-02801605.../dp/B000CEZOCS
E46 M3 Injectors -
Since everyone is sharing part numbers...0 280 158 117 are the injectors
Awesome! *I was wondering what the injectors were, are they bosch?
Z4M Injectors -
Originally Posted by bostongreen328i View Post
Interesting; for the Z4M 570 kit the injectors are Bosch 0 280 156 012 (41lb/hr 430cc/min).
Water Cooling Related:
Bosch Electric Water Pump - M-8501-L54 - $100 shipped from eBay
Electric Water Pump Relay -
HEL003530007
Water to Air Intercooler -
I was told that the inter-cooler is made by AKG, it is Porsche OEM part # 99610603751, used in the 2004-2005 996 Carrera & GT3. There are other companies like Behr that make a replacement, and they can be purchased for $200-300.
http://www.fcpeuro.com/products/pors...hr-99610603751
http://www.jimellisporscheparts.com/...ssembly=475765
Bleeding the water cooler system- This only requires a funnel and a container of antifreeze/coolant. I mixed my own in the pictured milk container (50% of 100% antifreeze/coolant and 50% distilled water), however you should use whatever works best for you i.e. water wetter:
Originally Posted by ILLuSioNz X View Post
Swapping the new pump in was an easy job, since I was able to do it without removing the s/c. Once I finished the install, I bled the cooling system (as required) and refilled the SMG fluid since I saw a SMG cog yesterday.
AA Supercharger Kits:
Engine Related:
Originally Posted by tripleblackrag View Post
For reference I have the Gen 3 Stage II with 8 rib pulleys & 70mm on the C38-81.
Here are the part numbers for the idlers, tensioner bearing, serpentine belt and rotrex oil filter...
Idlers: Koyo PU355816RR9H (Ebay $10 - $20). I bet you can find them way cheaper I just needed them quick. You need 2
Tensioner Bearing: Nachi 6303NSE 17mm/47mm/14mm (Ebay $10 shipped). Simple snap ring to remove it.
Oil Filter: Wix Filters 495-58964 - WIX Filters Magnetic Inline Transmission Filters 5/16 ($14)
Drive Belt - Gates Micro V - K080839HD I bought 3 of these on amazon for $19.35 shipped! under $5 a belt..crazy. They are fleetrunner and are heavy duty. The top of the belt is green which looks kinda cool.
Boost Lag Fix / Recirculation Pipe Delete
- Gibraltar Rubber 1.5" End Caps for stand with round feet ($2 Ebay). Fits perfectly with a hose clamp and made of sturdy rubber. Attach to the back of your AA snail and lose the 1.5" hose connection to your BOV. You should be running Alpha-N so vent to atmosphere is not a problem.
Contribution from BevsM3:
Tensioner Part # INA 11281427252 http://www.turnermotorsport.com/p-44...lternator.aspx
Tensioner Pulley - DAYCO Part # 89133 Drive Belt Idler Pulley; 70mm x 17mm Flat Steel, 24mm wide ~$16
Thanks for the addition BevsM3. You can aso find the same INA part at your local Autozone in stock (Duralast 305342) ~$54. Instead of throwing away the 6 rib pulley, I swapped it onto the AC tensioner - its the exact same pulley and bearing.
Originally Posted by toy4to View Post
Here's the parts needed for an Active Autowerk HKS Stg 1.5/2 kit. These are parts purchased from http://www.siliconeintakes.com Use coupon code link987 for 10% off.
These T-bolt clamps (are all stainless steel and of very good quality and cost $2.60 each). I highly suggest you use tbolt clamps instead of the worm-gear clamps supplied.
Clamps for the intake manifold:
12 x T-Bolt Clamp for 2.25" Silicone Parts (CLA000101) = $31.20
http://www.siliconeintakes.com/produ...212f51db27eb00
Clamps for various intercooler piping:
12 x T-Bolt Clamp for 2.5" Silicone Parts (CLA000102) = $31.20
Clamps for the intercooler ends
2 x T-Bolt Clamp for 3.0" Silicone Parts (CLA000104) = $5.20
If you needed to replace your silicone hose due to any tears or whatever, these are the parts needed. If it's a 2' section, cut it into smaller sections using a razor blade or a utility knife:
Intercooler ends:
2 x Silicone Reducer, 3.0" to 2.5" - Black (SIL000064) = $19.98
Intake manifold:
1 x 2.25" Silicone 2' Straight Hose, Black (SIL000041) = $39.99
http://www.siliconeintakes.com/produ...de3c86d16f72a8
Intercooler piping: you will need 2.5" diameter hose.
Supercharger & Methanol Related:
For reference I have the Gen 3 Stage II with 8 rib pulleys & 70mm on the C38-81.*
Oil Cooler / SC Feed Line - $50 at a specialty hose shop. I have already replaced the return line so no pics of that. My hoses were cracking really badly and were soon to spring a leak (rotrex oil is not cheap). Hose is 5/16 with a prime pump and 6 AN braided for a little flash.
Methanol Injection Line Upgrade - *Outlet side of the pump with 4 AN SS lines, check valve and nozzles from DevilsOwn Injection ~$100.
EDIT 8/5/12 - Upgraded the Meth pump to Devils Own 200 psi, Inlet line is Braided 6AN with XRP fittings and 6AN Billet filter
ESS Supercharger Kits:
Originally Posted by BrokenM3 View Post
For the Ess Vt2-550 kit:
Personally prefer the Gates micro-v belt part number K060915
I found the price to be best on ebay. I got each one for under $30.- shipped.
Ebay search: Gates K060915 Serpentine Belt
A big thanks goes out to Shadowless (M3F) for the thread idea. Thanks in advance to anyone who has or will be contributing to this thread.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Tue, Dec-18-2012, 08:56:17 PM   #2
curiouz_g
Reputation: 0 curiouz_g is on a distinguished road
Default Re: Supercharger Kit Maintenance Thread
This threads going to be awesome. We should also include any information on increasing boost in this thread as well with any part numbers from members who have done it before, IE going from 5lbs to 10lbs
Jump to top curiouz_g is offline   Reply With Quote
Old Wed, Dec-19-2012, 01:12:17 AM   #3
DM4paintballer
Member: Red Sox Nation
DM4paintballer's Avatar
Reputation: 0 DM4paintballer is on a distinguished road
Default Re: The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ES
Subscribed!
Base: 2005 Imola Red M3. 6MT.
Performance: VF 570 Supercharger. Clutch masters FX400. CAI setup w/ Dinan Stage 3 software. Borla exhaust w/ Borla mid. TCK D/A Front, S/A Rears, 500 # all around, TCK camber plates, UUC Evo 3 short shift. Volk TE-37 Time Attacks, 19 x 8.5 front (245s), 19 x 10.5 rear (285s). CDV Delete. BMW CCA Driving Schools. Brembo BBK.
Just Because I Like It: 13% all around tint. "Xenon" interior lighting. Umnitza Orion V2 Multi-color Halos. Carbon fiber (black/gray) Roundels. Black out front and side grills. LED smoked corners. SG front lip. Custom Whalen shift knob.
ICE: Kenwood KVT-516, Morel Tempo Coax 5 speakers, JL XD600/6 amp, custom trunk mounted sub with rear seat porting. V1 Hardwired. Blinder M20.
Jump to top DM4paintballer is offline   Reply With Quote
Old Wed, Dec-19-2012, 05:28:36 AM   #4
808elise
808elise's Avatar
Reputation: 0 808elise is on a distinguished road
Oh nice. Good job.
-Josh
Jump to top 808elise is offline   Reply With Quote
Old Wed, Dec-19-2012, 10:11:39 PM   #5
namstadamus
Reputation: 0 namstadamus is on a distinguished road
Awesome - thanks for starting this thread..
04 AW/Cin M3 Coupe
VF420
Jump to top namstadamus is offline   Reply With Quote
Old Wed, Dec-19-2012, 10:37:16 PM   #6
R10_Telemetry
Reputation: 0 R10_Telemetry is on a distinguished road
Monaco
Jump to top R10_Telemetry is offline   Reply With Quote
Old Thu, Dec-20-2012, 03:15:46 AM   #7
xdaznboi
xdaznboi's Avatar
Reputation: 0 xdaznboi is on a distinguished road
May i Suggest starting form basics, such as S/C oil change diy?
JVT rep Headers | KW V3| Ground Control Camber Plate|B&B Exhaust| AR 25 Resonator | Black Out Kit |CSL Diffuser| BMW Motorsport 4.10 | Work VS-XX | MOTORSPORT HARDWARE Stud Conversion Kit | AVT Air Scoop | Illuminated Door Sills | VF Engineering Stage 2 | Dr Vanos Cryogenically Treated Hub | Ignition Projects Plasma Coils | Vorsteiner CSL w/ One Piece Splitter | Carbon Fiber Side Skirt Extension | Carbon Fiber Mirror Cap | Hardwired V1
451.04 WHP 305.46 TQ SAE 91 Pump Gas
Jump to top xdaznboi is offline   Reply With Quote
Old Thu, Dec-20-2012, 10:03:38 AM   #8
VERTigo
Reputation: 0 VERTigo is on a distinguished road
Here is the AA maintenance thread that I and BevsM3 put together:
http://www.m3forum.net/m3forum/showthread.php?t=399022
Saad Racing Stage 3 Turbo + ProEFI & NX Nitrous on E85
Jump to top VERTigo is offline   Reply With Quote
Old Thu, Dec-20-2012, 10:31:28 AM   #9
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Good idea. Thanks for putting this up.
Old Thu, Dec-20-2012, 03:15:52 PM   #10
curiouz_g
For the self contained V3 units, all you have to do is undo the bolt at the bottom of the oil line and drain it. I'll post pics the next time I do my s/c oil change
Discussing The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
