PunjabiM3
![]() Location: Tucson, AZ
Well after running a search and also looking at the article on bimmer.roadfly.org on installing and wiring an aftermarket amp and speakers, I decided to take out the liner in my vert to check out the amp and also the smaller seperate amp for the HK sub. Well, only problem is that it IS NOT there in the vert. The wires that run to the HK sub (which I used to feed my line out converter for my current aftermarket amp/sub install) lead towards the driver side, then towards the back driver's side seat and then into the rear panel where it just disappears. So question is, where is the HK amp for the vert located at? Is it going to be a pain in the butt to take it out and place a nice aftermarket 4 channel amp in its place? Also, for those sub experts out there, where exactly did you tap into the factory wiring for your line out converter for the best SQ? Hope to get some answers and TIA.
Jay Sidhu
20011 1M, Valencia Orange, Berk mids, Eisenmann Race, KWV3, IND Gloss Black trim, MS 10mm spacers 2012 Audi A6, Moonlight Blue, Nougat Brown, Prestige Previous: 997 turbo, e92 M3, 997 C2S, e46 M3 coupe, e46 M3 cabrio |
Casper the Rasper!
![]() Location: Hayward, CA
I think it's in the trunk on the passenger's side opposite the CD changer, which is on the left side. I THINK.
#3 | |
![]() Location: Windermere, FL
They both worked very well and complimented the Harmon Kardon system to the point that it wasn't worth changing out the rest of the speakers. Just the added bass was enough to make the system much better. If you're interested PM me and we can talk pricing. Alden
2004 M3 SMGII | Imola Red | Black interior Mods: Performance: GC Complete Street coilover kit | GC front/rear sway bars | Power Flex RTAB | Stebro section 1 | Axxis Deluxe Plus pads | StopTech ss brake lines | OEM Euro rotors Exterior: 19” HRE 840R’s | Michelin Pilot PS2’s | CSL replica bootlid | platinum silver front grill | 3M clear bra | Imola Red hood washer grill,keyhole cover,reflectors,fog rings Interior: F1 alum SMG paddles | Alum pedals | chrome E-brake | silver carbon fiber interior trim Lighting: 6500K DDE’s with on/off switch | Xenesis fogs | 6000K XenoFlo HIDS Electronics: JL Audio 500/5 amp | Dynaudio 240MKII fronts | JL Audio VR650 CXi rears | Bavarian Soundwerks sub enclosure | JL Audio 10W1v2 subsx2 | XM Direct | Dension IceLinkPlus | Bluetooth | hardwired V1 | Blinder X-treme M-20 laser jammer DIY: DDE with On/Off switch & Remote Mod |
#4 | |
M Powered
![]() Location: Florida
#5 |
If you have any other questions or are looking into a setup, I just spoke with Jason at Bavarian Sound the other day and he made mention that they have a sub setup availible for the Cab sometime soon.
#6 | |
PunjabiM3
Jay Sidhu
#7 | |
M Powered
For the rear left panel removal you need to remove two Torx T20 screws at the armrest. Once you do that, just pry the panel out, it is held by pins. The speaker looks like 100mm. If you are going full aftermarket amplification, I do not see how you are going to fit an aftermarket amp where the HK is. At least any decent aftermarket amp, running 4 sets of speakers and a sub, will be almost twice as big in size as the OEM just because it will be pumping more power out. More power, bigger and better components, bigger heat sinks... bigger enclosure. As an example, my JL 250/1 running two subwoofers is bigger in size that the OEM running 10 speakers. |
#8 | |
PunjabiM3
Jay Sidhu
#9 |
![]() Location: Mesa, AZ
You must first pull off the speaker covers, then you will notice more screws, it will come off now.
2004 996TT Gaurds red/Black interior GT660 550 whp on 91 octane 2004 IMOLA CAB [/SIZE] |
#10 | |
PunjabiM3
Jay Sidhu
| BSW Stage 1 Updated - Standard Audio Systems Read To Ship | Halston Pitman | Audio/In Car Entertainment (I.C.E.) | 255 | Wed, Jul-29-2009 09:12:41 PM |
| 99 HK Audio Questions. Experts On Car Audio Only Please | jmeeder | E36 M3 (1992-1999) | 38 | Wed, Jul-30-2008 04:52:52 PM |
| Vert JL Audio.....Maxed Out | JADE46 | E46 M3 (2001-2006) | 5 | Wed, May-02-2007 05:43:07 AM |
| Read this....tails for Vert E46 | dm350z | General BMW Discussion | 1 | Thu, Oct-05-2006 03:13:13 AM |
| Advice before upgrade JL Audio '03 M3 Vert | Bmermanm3 | Audio/In Car Entertainment (I.C.E.) | 1 | Mon, Mar-07-2005 05:43:08 PM |
