Old Tue, Jan-04-2005, 06:27:41 PM   #1
LSD4me
Reputation: 0 LSD4me is on a distinguished road
Default EWS Bypass Workaround
I too was having painful issues with the EWS III in the 2004 E46's. I tried 3 different bypass modules until i made one myself.... 1st was the 555U universal...(Nope), then was the 555B module (Nope), and lastly the 556 which was supposed to replace the 555 models....NOPE
What i ended up doing is buying another Transponder Ring from BMW
(PN # 61 35 6 900 016) ($24.99) and used that in conjunction with 2 standard 30 AMP Bosch Relays. For those intereseted, read on:
1) The original Transponder Ring which is installed has 2 wires coming out. This connection needs to be severed and connected via the relays. Do one wire at a time. The new transponder ring is going to be installed as well using the same wire as the one from the original. Cut one of the wires and connect it to 1 relay as follows:
Pin 30 - Car side of the connection
Pin 87A - Ignition side of the connection
Pin 87 - Wire from NEW transponder ring
Pin 86 - Constant +12V
Pin 85 - Status Wire from Alarm or any (-) pulse
Once this is done, do the EXACT same thing to the other wire. This will in effect, activate the relay once a (-) signal is receieved and then will connect PIN 30 with PIN 87 which is the desired response. Viola. Attached is a makeshift diagram. Any questions, PM ME.
/// Club 333+
Jump to top LSD4me is offline   Reply With Quote
Old Tue, Jan-04-2005, 06:42:03 PM   #2
Sirius
How many licks..
Sirius's Avatar
Why are you bypassing EWS?
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Tue, Jan-04-2005, 07:23:10 PM   #3
LSD4me
Remote Starter Install.
...Now that I look back, only 1 relay would be needed for this to work...the other wire, just tap in to the existing connection.
/// Club 333+
Old Tue, Jan-04-2005, 07:28:46 PM   #4
Sirius
How many licks..
Sirius's Avatar
Gotcha.
97' M3. '10 R6.
Old Wed, Jan-05-2005, 04:00:01 PM   #5
Dan Law
Dan Law's Avatar
Reputation: 0 Dan Law is on a distinguished road
THANK YOU!
Could you please post the revised 1 Relay Diagramme?
Also, could this be simplified if one were NOT using an alarm? If so, could you please post a diagramme?
Great stuff!
Dan Law
Jump to top Dan Law is offline   Reply With Quote
Old Wed, Jul-13-2011, 09:46:58 PM   #6
Ruben Vazquez
Reputation: 0 Ruben Vazquez is on a distinguished road
Default Re: EWS Bypass Workaround
HI, I Want to put a start switch on my car, its a 1997 328i, ews II, i have the factory installed alarm with the 2 button fob, i wonder??? is there a way to bypass the ews so when i deactivate my alarm that i can start the car with just the switch, or the toggle switch and then the switch, WITHIUT the key, i have the alarm with the keyless entry so everytime i got off my car id double lock my doors and alarm would be in place, thats good enough for me
Jump to top Ruben Vazquez is offline   Reply With Quote
EWS Question kalzanoon E36 M3 (1992-1999) 15 Tue, Aug-29-2006 09:04:00 PM
EWS Bypass douglee25 E36 M3 (1992-1999) 12 Tue, Jan-04-2005 07:27:58 PM
ews problem lsmotors E36 M3 (1992-1999) 0 Thu, Dec-30-2004 06:22:32 PM
Ews 1 Or Ews 2 MARKSDIDDY92 E36 M3 (1992-1999) 3 Sun, Jun-06-2004 02:52:29 PM
EWS question Lee sawdon E36 M3 (1992-1999) 2 Mon, Sep-01-2003 09:15:45 AM
Discussing EWS Bypass Workaround in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
