Old Sat, Feb-05-2005, 07:27:30 PM   #1
atwork
Reputation: 0 atwork is on a distinguished road
Default Diff./axle seal problem
I just looked at the underside of my car on a lift as the belts were being replaced. The passenger axle and differential connection looks like it has developed a leak as there is clearly fluid covering both areas. I haven't ever seen any fluid drips on my driveway or garage floor. Has anyone experienced this problem before? This may seem like a small problem but I am concerned about it. My car just hit 36k miles, it's an '01 model year. Any comments or suggestions are welcome. TIA
Jump to top atwork is offline   Reply With Quote
Old Sun, Feb-06-2005, 02:44:18 AM   #2
Thrill
Thrill's Avatar
Reputation: 0 Thrill is on a distinguished road
If it is not actually leaking, just turned the area where they fit together dark, I would not worry about it. I have seen that several times and it’s not that unusual. Often times it will be that way on both sides.
2004 M3 SMG LSB Black Nappa Prem. Pkg.
19s Shoot Bear When Bear In Season
Jump to top Thrill is offline   Reply With Quote
Old Thu, Feb-17-2005, 09:30:52 AM   #3
Kendrick07
Kendrick07's Avatar
Reputation: 0 Kendrick07 is on a distinguished road
South Korea
anytime fluids are leaking from a car, it isnt good. I think that is common. Have it checked out.
12 Honda CBR 1000RR - Jet Black
09 Lexus GS350 - Sapphire Pearl/Black
04 M3 Coupe SMG - Jet Black/Black (sold)
Jump to top Kendrick07 is offline   Reply With Quote
Old Thu, Feb-17-2005, 12:49:03 PM   #4
tec548
tec548's Avatar
Reputation: 0 tec548 is on a distinguished road
Welcome to the ever growing group of M owners that have a bad M-variable diff unit. Don't worry everyone else will eventually be in this group with you.
Jump to top tec548 is offline   Reply With Quote
Old Fri, Feb-18-2005, 02:14:08 AM   #5
kmurph
Reputation: 0 kmurph will become famous soon enough
Does this look familiar???
I don't know where to begin...I'm already on my second diff. I had a remanufactured diff put in over a year ago after noticing a lot of fluid around the output shaft seals.
These pics were taken a few months ago so it's the new diff. Along with the fluid, I also noticed a lot more noise coming from the diff. I thought maybe the fluid needed to be changed so I flushed out the old fluid and replaced it with Redline...the noise definitely decreased and it drove much smoother but there was still some noise when making tight left turns...noise that was never there before.
I took it to the dealer and they said that an output shaft flange needed to be replaced...I had that work done along with the bearings SA...and while doing that they found 3 leaking power steering line...but that's another story ...
Well, after the flange was replaced and fluid changed with the BMW "special" fluid from the Diff Service Bulletin, the noise still exists...oh well. I'll have to keep an eye on it to see if there is anymore leaking.
2007 Audi RS4 / GMG Exhaust
2001 BMW M3 - sold
Jump to top kmurph is offline   Reply With Quote
Big thanks to Forum Member Jest - Diff Seal Install DIY tonggi Northeast 26 Thu, Feb-28-2013 05:47:54 PM
Front diff seal replacement DIY? sssimmon E46 M3 (2001-2006) 0 Sun, Jun-29-2008 07:00:43 PM
Diff seal questions johnclarke E46 M3 (2001-2006) 3 Sat, Apr-12-2008 09:45:00 PM
causing a diff problem? papertiger E36 M3 (1992-1999) 4 Thu, Apr-19-2007 05:58:37 AM
Rear axle/shaft seal leakage common in M3? desiyaar E46 M3 (2001-2006) 2 Mon, Jun-26-2006 08:24:35 PM
Discussing Diff./axle seal problem in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
