Old Mon, Jan-15-2018, 08:30:32 PM   #1
HassanEido
HassanEido's Avatar
Lebanon
Default My Custom CF Airbox Journey Begins
Welp. It's that time of the year again.. Another custom project has begun. A couple of people here know I've been toying with the idea of creating my own csl airbox.. inspired by an old thread of a guy who actually did his own box a couple of years ago, I figure what the hay-Why not
So I bought 8 square meters of 200 grams per meter twill weave carbon fiber fabric, epoxy resin, bought a spare stock airbox to reuse the trumpets and backing,took a couple of online courses on composites, and ordered a csl filter, which should be arriving this weekend.
I plan to make a foam form and wet lay cf on top of it to make my box,clocking the weave layer by layer to achieve max composite strength,for my first iteration anyway.
I'll be updating this thread when I start working on it, and when the time comes with dyno graphs as usual.
Here's a teaser for now :
Edit: Results and Dyno and vids:
http://m3forum.net/m3forum/showpost....&postcount=123
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Mon, Jan-15-2018, 08:50:57 PM   #2
Brian N
wubalubadubdub
Brian N's Avatar
Default Re: My Custom CF Airbox Journey Begins
Whoo hooo finally!
-My Journal-
Old Mon, Jan-15-2018, 08:53:51 PM   #3
SWRTstang_M3
Custom X
SWRTstang_M3's Avatar
Reputation: 0 SWRTstang_M3 is on a distinguished road
this is going to be a very interesting thread, can’t wait to see what you come up with, best of luck and thanks for sharing this and your exhaust project with us, true assets to the community
  • M3 SMG (Stock) • MartynT Tool • SAP Delete • TMS Power Pulley Kit • TMS RSM • Koni 1140 Sport Suspension Kit • Powerflex Race Differential Bushings (F&R) • ECS 80A Transmission Mount Set • ECS RST Reinforcement Plates • Michelin PSS • Depo Smoked Corners
Jump to top SWRTstang_M3 is offline   Reply With Quote
Old Mon, Jan-15-2018, 08:59:39 PM   #4
Good for you! Good luck and this will be fun to watch!
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1· OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE· ZHP "712" rack
DD: 2012 TiAg/Blk 128i · N52 · ULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 FCAs
Old Mon, Jan-15-2018, 09:06:43 PM   #5
lmtfi
lmtfi's Avatar
What are you going to use for a mold?
Old Mon, Jan-15-2018, 09:29:19 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
Thanks guys! You support means a lot.
@lmtfi , I have two options, both of which will reuse part of the stock box.
I figure the underside is perfect and durable, and the backside (throttle body side) is perfect and holds the stock trumpets nicely which I also plan to re-use. These parts will be carbon overlayed plastic. The top part and intake side will be cut open, and a foam plug will be made as a form that I will use to wet lay cf over it, which would then be fused to the filter flange(also made from a foam form and wet laid cf over it to snuggly hold the filter) . I have a gsr box that I can use for measurements and to template the snorkel etc.
Thats my plan for the first iteration anyway.
I promised a couple of friends to recreate this for them too. For that I would create a fiberglass mold and infuse resin into dry cf under vaccum.. the latter being more time consuming but repeatable, the former being easier for a 1 off project.
I'll try to document the entire thing
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Jan-16-2018, 03:55:47 PM   #7
HassanEido
HassanEido's Avatar
Lebanon
So something arrived in the mail today...
IMG-20180116-WA0014.jpg More pics to come when I get off work
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Jan-16-2018, 04:33:40 PM   #8
BMWjunkie11
That guy
BMWjunkie11's Avatar
Reputation: 0 BMWjunkie11 is on a distinguished road
Oh I'm tuning in to see how this turns out. Good luck with this!
2002 Jet Black/Grey ///M3
Full Supersprint Race Exhaust l PSDesigns Velocity Stack Kit l TMS Pulleys l TTFS Custom Alpha-N Tune l Work Brombachers
"Bags are for dead hookers"
Jump to top BMWjunkie11 is offline   Reply With Quote
Old Tue, Jan-16-2018, 06:03:46 PM   #9
bjz
bjz's Avatar
Reputation: 0 bjz is on a distinguished road
Spain
popcorns!
Jump to top bjz is offline   Reply With Quote
Old Tue, Jan-16-2018, 07:27:11 PM   #10
M3_Pilot
M3_Pilot's Avatar
This is awesome! Do you think this will cost as much as buying one?
2004 Jet Black/Cinnamon 6MT
@anthonyy.m3
Discussing My Custom CF Airbox Journey Begins in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
