Old Thu, Apr-21-2005, 04:49:29 AM   #1
ast
Reputation: 0 ast is on a distinguished road
Default New M3, SMG won't shift in Auto mode(PIC)
Just picked up my new M3 from dealer a few hours ago. Used AUTO mode level 3 when drove home and everything works fine, the car can shift nicely by itself correctly. Then I went for a short test drive around neigberhood in AUTO mode Level 3 again, but it seemed won't shift automatically anymore, so I have to upshift manually, but the indicator still shows 'D' which means AUTO, right?
did I do somethin' stupid?
Also just to share some pics.
Jump to top ast is offline   Reply With Quote
Old Thu, Apr-21-2005, 04:58:37 AM   #2
DaBean
Smurf Driver
DaBean's Avatar
Reputation: 0 DaBean is on a distinguished road
France
oh no...
if it show D, it means, press to the right to go to D mode...... when you're in Auto, you'll see a much bigger D displayed to the lower left, and a little S to the right..
it's sort of confusing.. I thought mine was backwards too when I got it...
-Fabien
NASA NorCal Region Instructor
*SMG Loverz Club*
Jump to top DaBean is offline   Reply With Quote
Old Thu, Apr-21-2005, 05:01:35 AM   #3
Lone Wolf
Lone Wolf
Reputation: 0 Lone Wolf is on a distinguished road
D? Hmmm. If you're in Auto mode, there should be an "A" on the bottom right of the displayed gear that you're in. If there is an "A" on the right of the "crosshairs" in that little display screen, that means if you move the shifter to the right, you will activate Auto mode.
If you want Auto... There should be an "A" next to the gear # and an "S" on the right side of that screen showing that if you push the shifter to the right you'll be in "Sequential Manual".
-Will
'02 M3 SMG Alpine White, 19" SSR GT3's, ACS Roof Spolier, Red Leather int, Hamann: Fog Light Kit, Eyelids
Jump to top Lone Wolf is offline   Reply With Quote
Old Thu, Apr-21-2005, 05:06:52 AM   #4
DaBean
Smurf Driver
DaBean's Avatar
France
no.. . 03.5 and higher the A is replaced by the D...
-Fabien
*SMG Loverz Club*
Old Thu, Apr-21-2005, 05:09:12 AM   #5
Lone Wolf
Lone Wolf
Ahhh, my apologies for complicating the situation further. Good luck.
-Will
Old Thu, Apr-21-2005, 05:10:41 AM   #6
DaBean
Smurf Driver
DaBean's Avatar
France
'tis ok... you learn new things everyday... I honestly don't know why they changed from A to D... maybe one really bored Electrical Engineer got a hold of the SMG software?!?! who knows...
-Fabien
*SMG Loverz Club*
Old Thu, Apr-21-2005, 05:32:46 AM   #7
ast
Acording to the Manual: while driving in AUTO mode and I press the two levers on steering wheel, it will change to S mode. But mine didn't, still showing D. I will have to practice a little tomorrow.
Old Thu, Apr-21-2005, 05:47:20 AM   #8
Beowoulf
Dr. Evil Returns
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
If you use the stick or paddles to change gears in auto mode, it will switch the system to manual mode. You do not use both paddles at the same time except to reset SMG but that is a different matter.
Alex
Jump to top Beowoulf is offline   Reply With Quote
Old Thu, Apr-21-2005, 06:32:28 AM   #9
cowboy bebop
Trained Satirist
cowboy bebop's Avatar
Reputation: 0 cowboy bebop has disabled reputation
Denmark
ignore the shift "Tree" and just look at the "Gear Indicator Display" if you are in Auto mode (D instead of A on 04+, not 3.5) it will show a small "D" at the bottom of the indicated gear, if there is no "D" shown there you are in "S" mode.
ANYTIME you move either the stick, or the paddels you will automaticaly revery to "S" mode.
the "Tree" can be confusing, since it shows the options you can chose,from where you are now, rather than which mode you are actually in.
HTH.
"It is Pointless, and endless trouble, to cast a stone at every dog that barks at you" -Anonymous
Jump to top cowboy bebop is offline   Reply With Quote
Old Thu, Apr-21-2005, 07:29:16 AM   #10
ast
HTH.
Thanks! I am so relieved ... for a momnet I thought I might have done somthing stupid and 'broke' the car! I will be in Bimmerfest in two days and simply can't aford not having the car.
SMG Auto mode Quixotic E46 M3 (2001-2006) 18 Sat, Sep-15-2007 04:08:17 PM
SMG Downshift to 1 in Auto Mode EvanstonEddieM3 E46 M3 (2001-2006) 2 Wed, Apr-11-2007 03:22:05 PM
smg auto mode car won't shift daddys///m E46 M3 (2001-2006) 2 Thu, Sep-15-2005 11:26:44 PM
Slotting the M from D (Auto) to SMG Mode. BMW F1 E46 M3 (2001-2006) 6 Tue, Oct-12-2004 06:25:48 PM
SMG I Auto mode. adeyboy E36 M3 (1992-1999) 2 Thu, Aug-28-2003 02:23:57 PM
Discussing New M3, SMG won't shift in Auto mode ... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
