Old Tue, Jun-14-2005, 09:08:17 PM   #1
o8OneLight8o
Lunch Box
o8OneLight8o's Avatar
Reputation: 0 o8OneLight8o is on a distinguished road
Default Symptoms Of a Dirty Idle Control Valve.
Can anyone provide these symptoms for me?
If it's dirty are the symptoms intermittent or constant?
Thanks!!
, GaryO
1997 M3 Sedan, Artic Silver, Lux Package
Sports Suspension, Short Throw Shifter, Cold Air Intake, Upgraded Audio
"Be aware of the devil stay level. Confusion makes this world go round, corruption's got our lives locked down. So when I meet good people along the way, I get down on my knees and pray, and I never have to worry, this world was made for me. So I sing a song of peace and joy I know this world cannot destoy, and I never have to worry, this world was made for me."
Jump to top o8OneLight8o is offline   Reply With Quote
Old Wed, Jun-15-2005, 05:27:31 PM   #2
deilenberger
deilenberger's Avatar
Typically a poor idle. M3 engines (S52) tend to idle a bit rough when running perfectly, and tend to try to stall a bit when cold, but if your idle is really rough, or it idles too high at times, chances are your ICV could use cleaning.
I cleaned mine - car has 83k on it - and it needed it.
A few hints on doing the job:
1. Remove the dipstick assembly completely. The ICV mounts to the same bolts into the manifold so you have to take them out anyway. The dipstick tube just goes into the engine casting with an O ring, which on mine was in good condition.
http://www.realoem.com/bmw/showparts.do?
model=BK93&mospid=47479&btnr=11_1486&hg=11&fg=10 <<-- part #9
Having it out of the way allows you easier access to the ICV.
2. Remove the intake boot (the big rubber boot between the MAF or the ASC throttle body - if your car is so equipped.) Remove the ASC throttle body if your car has one - leave it connected to the cable and just put it out of the way.
There is one hose connecting to the ICV. Disconnect it at the other end (where it goes into the intake boot), then after removing the retaining bolts, pull the ICV straight down. It seals into the bottom of the manifold with a rubber ring.
http://www.realoem.com/bmw/showparts...81&hg=13&fg=15 <--- part 9, part 8 isn't used on our cars.
You might want to replace this ring since you are taking the ICV out. Mine was in good shape, but one used in a climate with high ozone levels (west coast) may not be. In any case - I'd suggest lubricating the rubber ring with silicone lubricant of some type before trying to reinstall the ICV.
3. Once you have it out - spray the inside liberally with a good carb cleaner while holding the ICV by the body. Grip is so you can rotate your hand and the ICV rotates. Do this so the actual valve inside turns as you spray the cleaner (as usual - wear eye protection and don't breathe this stull, it's nasty.)
Installation is the reverse of..
BTW - you might also consider R&R of the intake throttle body for cleaning at the same time... since you have all the other stuff out of the way - it's only four nuts to remove it. THe TB can also cause erratic idle as it gets cruded up. Check both sides of the butterfly for crud, and open it and carefully clean (with carb-cleaner on a rag) the bore.
Don Eilenberger
Old Wed, Jun-15-2005, 05:35:40 PM   #3
RoodAwakening
The Curmudgeon Cop
RoodAwakening's Avatar
Reputation: 0 RoodAwakening is on a distinguished road
Informative post, Don. Thanks.
Jump to top RoodAwakening is offline   Reply With Quote
Old Tue, Jun-14-2011, 05:53:53 PM   #4
OahuMPower
:FACEPALM:
OahuMPower's Avatar
Default Re: Symptoms Of a Dirty Idle Control Valve.
Originally Posted by deilenberger View Post
Typically a poor idle. M3 engines (S52) tend to idle a bit rough when running perfectly, and tend to try to stall a bit when cold....
Let me start with, I know this is a MASSIVE bump from the dead, but I cant leave this mis-information just hanging out there...
wtf u talking about Don? A perfect running M3 is exactly that.. Perfectly running. If the car doesnt have a problem, it will run as it should, with a smooth idel, and NOT try to stall when cold.
Where do you get this stuff?
Old Tue, Jun-14-2011, 07:14:49 PM   #5
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
This.
My car (97K on the clock) starts and runs perfectly smooth when cold. Even when I had a crack in the intake boot before the TB (which connects to the ICV), the car only idled rough for about 20 seconds and never, ever stalled when cold.
I would check this boot and the hose that runs from the boot to the ICV, as these get hard and crack over time, leading to poor idle and the occasional "bouncing" idle. Much easier to do this first than removing and cleaning the ICV.
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Jump to top propchef is online now   Reply With Quote
Old Tue, Jun-14-2011, 07:23:15 PM   #6
Magic M3
Magic M3's Avatar
Reputation: 0 Magic M3 is on a distinguished road
Also you dont have to take the dipstick tube out to remove the ICV, very doable with it in......
"What, that?....Oh, it's Stock....ish!"
Jump to top Magic M3 is offline   Reply With Quote
Old Wed, Jun-15-2011, 05:58:12 PM   #7
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
Here we go..........
:popcorn:
Jump to top WRXEATR is offline   Reply With Quote
Old Thu, Jun-16-2011, 12:39:06 AM   #8
eatsleeplax
Car Enthusiast
eatsleeplax's Avatar
Reputation: 0 eatsleeplax is on a distinguished road
:popcorn:
woot woot
Jump to top eatsleeplax is offline   Reply With Quote
Old Thu, Jun-16-2011, 01:03:05 AM   #9
white-hot
is lurking around the corner
white-hot's Avatar
SHOWTIME!
Old Thu, Jun-16-2011, 03:42:18 AM   #10
OahuMPower
:FACEPALM:
OahuMPower's Avatar
:popcorn:
no popcorn required. Doesnt matter who posted that information, I would of done the same thing, it just happens to be a mod, who just so happens to have issues with some of us.
Wrong information was put out, and I corrected it. Plain and simple
P1637 fault code: Throttle Valve Position Control; Control Deviation bagzman E46 M3 (2001-2006) 15 Mon, Apr-28-2014 11:40:38 PM
Idle Control Valve nutz330ci E46 M3 (2001-2006) 7 Tue, Sep-11-2007 03:48:01 AM
Idle Control Valve: Is this my problem? o8OneLight8o E36 M3 (1992-1999) 6 Sat, Apr-02-2005 01:27:27 AM
Idle control Valve replacement/cleaning IIrjII E36 M3 (1992-1999) 0 Mon, May-17-2004 10:12:33 PM
Idle Control Valve MegaJP E36 M3 (1992-1999) 2 Wed, Feb-18-2004 08:57:09 AM
Discussing Symptoms Of a Dirty Idle Control Valve. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
