Old Thu, Jun-16-2005, 05:37:13 PM   #1
m3indamakin
Reputation: 0 m3indamakin is on a distinguished road
Default Rear Toe Alignment problems... GC C/O's... Too much toe out!!..
I got the gc coilover kit, new bushings, and new tires. Not too long ago i installed the lower control arm adjustable links. At there shortest setting my camber is at -1.9 degrees both sides. It is just a bit a lower than stock now, not dropped too much.
My concern is that i dont know how to get toe within spec? I have sever toe out, and i dont know where else there is adjustment. The movement in the two toe adjustment "buckets" is maxxed out in its travel/swing side to side. Why do i still have toe out though? The GC coilovers are practically set at max height in the rear. I dont gets whats wrong.
My new rear tires that are a month old are already 1/2 burnt through, so there is a problem here...
Jump to top m3indamakin is offline   Reply With Quote
Old Thu, Jun-16-2005, 10:21:57 PM   #2
KitW
KitW's Avatar
Reputation: 0 KitW is on a distinguished road
The toe adjustment should be done at the trailing arm to body joint, not the camber adjustments. Find a better alignment shop, dude.
My ex-05 Imola Red M3 w/ Magnaflow and K&N 63-1115
Jump to top KitW is offline   Reply With Quote
Old Fri, Jun-17-2005, 02:32:45 AM   #3
m3indamakin
hmm, maybe you misunderstood. When i mean the "bucket" that swivels side to side, i meant the trailing arm adjustment for toe. The end of the bushing sits in a bucket that slides in grooves side to side for adjustment.
I know how to align cars, but i didnt need a professional to look at it to tell me its maxed out. Wondering why its so off tho..
read better next time. i didnt even say i took it to an alignment shop. dude
toe alignment- inch to degree? BlueGumby M3 Track: Racing and DE 2 Thu, Feb-28-2008 05:46:09 PM
Read this if your index toe is longer than your big toe!!!! marv800 Off Topic 21 Fri, Mar-16-2007 02:50:21 PM
diy rtab toe in alignment floydturbo E36 M3 (1992-1999) 4 Sat, Jan-27-2007 02:02:44 AM
Dumb question- lowering makes toe in or toe out? wadd3456 E46 M3 (2001-2006) 6 Mon, Jan-23-2006 05:25:44 AM
toe to toe with a AMG CL55 honger12 E46 M3 (2001-2006) 20 Fri, Apr-30-2004 04:48:29 AM
Discussing Rear Toe Alignment problems... GC C/O's... Too much toe out!!.. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
