| Audio/In Car Entertainment (I.C.E.) Place to discuss sights and sounds. |
![]() Location: Brooklyn
the signal from a stock headunit on an e46m3, is it delivered as a balanced or unbalanced signal.
i got an audiocontrol dqx and thier are jumpers in the unit for unbalanced/balanced.... any advice... its on balanced jumper setting - as default from audiocontrol... btw, i ran the headunit output wires and soudered RCA tips to them. it sounds great...(audio controls advice) basically bypassing a high/low converter, which was inducing noise into the system... just want to know, does the m3 come with balanced or unbalanced outputs. |
Audio guru with ///M in the blood
![]() Location: Charlotte
Try the balanced input.
The head unit in the E46 M3 (business class cd player) is not exactly balanced or unbalanced. It is a differential output +/- 6 volts. Good luck with it. The approach you are taking is an excellant one! |
#3 | |
thanks! mike |
| Corner balanced ...HELLLO! | z4man | E46 M3 (2001-2006) | 19 | Wed, Jun-04-2008 11:46:50 PM |
| RE: Staggered? or Balanced? | SC5-Charles | M3 Track: Racing and DE | 11 | Tue, Aug-23-2005 10:03:58 PM |
| more than the standard unbalanced wheels | PurpleM3Pursuit | E36 M3 (1992-1999) | 9 | Mon, Jun-20-2005 01:39:17 PM |
| Finally corner balanced | Ryun43 | E46 M3 (2001-2006) | 7 | Fri, Jul-23-2004 04:43:19 PM |
| Are your tires balanced correctly? | Ced | E46 M3 (2001-2006) | 11 | Mon, May-10-2004 06:03:13 PM |
