Old Sun, Sep-25-2005, 11:22:46 PM   #1
MyE36M3
MyE36M3's Avatar
Reputation: 0 MyE36M3 is on a distinguished road
Default Need some info on Intrax ARS Coilovers (pic.)
Yo guys,
I am thinking that I want to put a set of Intrax ARS Coilovers on my 95 E36 M3. Does any one have experience with them? If so, can you tell me about them? I am trying to research them on the forums, but when I do a search it comes up with very little in the way of information. Also does any one know a good place where I can purchase them? Any help would be appreciated.
Be safe, be smart, take it to the track!
Jump to top MyE36M3 is offline   Reply With Quote
Old Mon, Sep-26-2005, 10:21:57 AM   #2
m3buzz
///M3Buzz
m3buzz's Avatar
Reputation: 0 m3buzz is on a distinguished road
[QUOTE=MyE36M3]Yo guys,
I am thinking that I want to put a set of Intrax ARS Coilovers on my 95 E36 M3. Does any one have experience with them? QUOTE]
Hey - you're right, you don't see much about the Intrax stuff, but I have a set installed on my 87 Supra, and they've been great - nice amount of lowering and the ride is firm but not overly harsh. I mention it because at the time, I bought a set for the M3 too - I still have them, they've never been installed. If you wanted to take these and set them up with Konis or Bilsteins and make your own setup, I'd give you a decent deal, because I was going to eBay them. I did get some technical help from the Intrax website, so you might try there - they respond to email questions.
Good luck with the research.
///M3BUZZ
GC CoiloversOPN Welded!
UR Underdrive Pulleys, RD Sways/UUC links, UUC Evo3 SSK, UUC TMEs,UUC System U, Fluidyne Alum. Rad., SS Brake/Clutch Lines,
M50,X-Brace, Halos/Projectors/6000k,Clears, Fan/ASC/CDV Delete, Stewart HD WP, Euro Rotors, VDO Console Gauges, Custom CAI
///Team Contour
Jump to top m3buzz is offline   Reply With Quote
Old Mon, Sep-26-2005, 01:26:33 PM   #3
bartolome1
bartolome1's Avatar
Reputation: 0 bartolome1 is on a distinguished road
You would be the first person I've heard of using these coilovers on an M3. That's how much info there is.
The general consensus is that Intrax will "slam" your ride but aren't very suitable for track/autoX applications. But that's only from what I've read on forums. I have no personal expereince with them.
Good luck, let us know what you decide to do.
98 M3/4
03 540iT
Jump to top bartolome1 is offline   Reply With Quote
Old Mon, Sep-26-2005, 02:00:39 PM   #4
PurpleM3Pursuit
E36 on the way out... E92 on the way in..
PurpleM3Pursuit's Avatar
Reputation: 578 PurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond repute
indeed.. my GC's are doing fine.. i have seen much on intrax either.. actually never thought of looking since there is a pretty decent selection for our cars as it is..
Alex... or PM3P... being a good Leader for YOU!
E92 M3 AW/BL Competition
BMWCCA# 368302
Also in the fleet:
'75 Porsche 911 Carrera
'85 Chevrolet Camaro Z28
'87 Porsche 951
'95 BMW 325i GTS2/JP
'15 F150 EB SCrew
Jump to top PurpleM3Pursuit is offline   Reply With Quote
Old Mon, Sep-26-2005, 02:09:04 PM   #5
Dan Law
Dan Law's Avatar
Reputation: 0 Dan Law is on a distinguished road
Dude!
Get the real deal. Let me quote you on a Ground Control or TC Kline set-up.
Email my business:
dermotorsports@gmail.com
Dan Law
DERMotorSports@gmail.com
770.631.0125
www.DERMotorSport.com under construction
Dan Law
DERMotorSports
770.631.0125
DERMotorSports proudly carries: TC Kline, AST, Moton, PowerFlex, Vorshlag, Rogue Engineering, SPAL, SPA, Cobra, Schroth, Brembo, AP Racing, StopTech, Performance Friction, TireRack, ATL, TC Design, Eisenmann, Remus, Larini, SuperSprint, AC Hydraulics, Stand21, Racing Radios, CDOC, RRT, UUC, Zionsville Auto, RaceTech Seats/Harnesses, Sparco, MOMO, Audison, Hertz
New line announcements forthcoming!
Jump to top Dan Law is offline   Reply With Quote
Old Mon, Sep-26-2005, 03:22:39 PM   #6
Tpb31
Tpb31's Avatar
Reputation: 0 Tpb31 is on a distinguished road
I have heard that with the Intrax it doesn't come with a sway bar linkage...or was it that you have to weld your own linkage mouting point onto it. Check on that becuase I am not sure if you want to go around welding things to your suspension.
Jump to top Tpb31 is offline   Reply With Quote
Old Mon, Sep-26-2005, 04:24:47 PM   #7
bartolome1
bartolome1's Avatar
Or you could do what people with the PSS9 kit do and use the swaybar links from a non-M E36. Instead of mounting to the strut housing, the links mount to the control arm.
98 M3/4
03 540iT
Old Mon, Sep-26-2005, 06:29:34 PM   #8
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
pss9's now come with the correct m3 swaybar mounts.
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline   Reply With Quote
Old Tue, Sep-27-2005, 01:01:20 AM   #9
m3buzz
///M3Buzz
m3buzz's Avatar
Should also mention that I didn't install the Intrax because i went with the Ground Control street/track coilovers - great set up and infinitely adjustable without removing them from the car - a couple of turns either way from the top of the shock and you're off to the track or whatever.
You'll need to decide what you want from the suspension when you're done - if you're going to track it, I'd forget the Intrax and check out Ground Control. Ride height alone, and if cost is a big concern, the intrax might be o.k.
///M3BUZZ
///Team Contour
Old Tue, Sep-27-2005, 01:40:26 AM   #10
MyE36M3
MyE36M3's Avatar
According to the Intrax info i have here the M3 coilovers have a different part number than the non M3 E36, this leads me to believe it would have the sway bar link attached to the damper casing. This is actually why I have not pursued a coilover for my car as yet. I was having a hard time finding specific M3 coils that had what i wanted.
The other issue I've had is finding a coilover that is both height and damping adjustable for BOTH FRONT AND REAR, sorry for caps. Just important point.
My car is an auto, ya i know, it's my cruiser. So I'm looking for something comfortable. I work for a Japanese suspension importer, Endless/Zeal, and like the "twin perch" aspect of their coils which i rarely see from euro manf. Unfortunately the INtrax doesn't have that, but it has the other traits.
The place i work for is also a GC distributor and we've tried the GC kits, with "ok" resuts in comparison to our Japanese coils, not BMW specific. I think I'd prefer something integrated and valved accordingly. I emailed TC cause I liked their kit as well, but we can get a killer deal on the intrax coils. It seems that they are Koni dampers, but have been valved. The intrax materials also indicate that they can custom valve these for me with spring rates i specify. This interested me because I didn't want to buy Konis and then have them valved again or pay a larger price for valved ones.
I really appreciate you guys responding to this cause I've been wanting coils for like 4 years now but haven't found anything I could both afford and give me all the attributes i'm looking for. Sorry for the long post, just wanted you guys to know what I'm looking for and where i'm coming from.
Thanks.
Intrax 1K2 coilovers installed Kin Mak E46 M3 (2001-2006) 26 Mon, Apr-07-2008 07:45:51 PM
hks coilovers? any info JTrejo E46 M3 (2001-2006) 3 Sun, Dec-09-2007 12:52:49 PM
BBS pic/info request utlucas E36 M3 (1992-1999) 20 Fri, May-11-2007 04:10:47 AM
Looking for info/feedback on ground control coilovers domino_z E46 M3 (2001-2006) 25 Thu, Apr-19-2007 01:09:30 PM
Searched,but couldnt find any info. Anyone have info on FK coilovers? woptang22 E46 M3 (2001-2006) 25 Sat, Apr-22-2006 02:29:16 AM
Discussing Need some info on Intrax ARS Coilovers (pic.) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
