Old Mon, Oct-03-2005, 12:12:38 PM   #1
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
Default Cylindar Misfire + EVAP large leak detected
This morning my car was running extremely rough. Sure enough, the Check Engine came on. I got two codes - Cylindar #5 misfire and large EVAP.
Are these related? It certainly seems to have a misfire. Is it safe to drive it to the garage (5 miles)?
Thanks
Jump to top bigneil is offline   Reply With Quote
Old Mon, Oct-03-2005, 03:10:51 PM   #2
99M3Riverside
Reputation: 0 99M3Riverside is on a distinguished road
Were you low on Gas. I got similar codes when I was dead emptly made it to the gas station cleared the codes and never had an issue.
Dan
Jump to top 99M3Riverside is offline   Reply With Quote
Old Mon, Oct-03-2005, 04:05:10 PM   #3
goob_os101
goob_os101's Avatar
Reputation: 0 goob_os101 is on a distinguished road
I had misfire in 5th and 6th cylinders and still have not pinpointed the prob...the stealership said valves and wanted $5100-$6000 so I hauled the M off. I am having a compresion test done hopefully today and I'll check with Turner Motor Sports(TMS) with the numbers. They are going to be doing the work on my M3. I was just driving around 60MPH in 3rd and lost all power. TMS wants me to see if I did not drop a vavle. Im leaning towards bent valves. TMS priced it around $1500-$2000 to rplace the valves. I would tell you also to do the same. When you press the gas does your car shutoff, when you shut the car off do you hear air come out of the engine, and does your car sound louder and more like a WRX? thats what mine was doing.
Jump to top goob_os101 is offline   Reply With Quote
Old Mon, Oct-03-2005, 04:50:30 PM   #4
bigneil
bigneil's Avatar
I think I just had a failed ignition coil. I got #5 ignition coil as another code after I drove it to the repair shop (and it was quite rough).
Old Mon, Oct-03-2005, 07:02:46 PM   #5
goob_os101
goob_os101's Avatar
I repaced both coil pack on mine and didn't do a thing
Old Mon, Oct-03-2005, 11:43:43 PM   #6
bigneil
bigneil's Avatar
Turns out it was a bad ignition coil. Still not sure why the EVAP warning came on but I didn't ask.
Old Wed, Oct-05-2005, 12:02:37 AM   #7
bigneil
bigneil's Avatar
The EVAP came on because I wasn't burning the gas with the misfired cylindar. That went away with the other codes. The thing threw more signals than Jason Varitek.
Old Tue, Feb-28-2006, 03:48:44 AM   #8
tailhappy
Reputation: 0 tailhappy is on a distinguished road
Goob_os101,
What was the rpm stumble problem/ misfire from July 2005.
I have a similar problem in my 1997 M3..
tailhappy
Jump to top tailhappy is offline   Reply With Quote
Old Tue, Feb-28-2006, 03:50:41 AM   #9
tailhappy
Hi bigneil,
What was the rpm drop / misfire issue you had?
.. like the washer!
tailhappy
Old Tue, Feb-28-2006, 03:52:51 AM   #10
tailhappy
The EVAP valve is in the trunk underneath the spare. Just vacumn out the valve and replace. I hit a few dirt roads and have to do this all the time to clear the code. (need a torx driver).
detected oil leak.. help sam Hsu Faults, Fixes and DIY 1 Mon, Mar-17-2008 11:24:36 AM
Misfire detected , Cyl #2 phantom3 E36 M3 (1992-1999) 9 Tue, Feb-05-2008 01:08:49 AM
EVAP leak khezik E46 M3 (2001-2006) 2 Fri, Sep-21-2007 01:14:04 PM
Fault Code FB - EVAP small leak detected 1999 Dinan M3 E36 M3 (1992-1999) 3 Thu, May-05-2005 03:09:32 AM
Large EVAP detected SanfordW E36 M3 (1992-1999) 0 Thu, Jul-04-2002 04:29:00 AM
Discussing Cylindar Misfire + EVAP large leak detected in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
