Old Mon, Oct-31-2005, 04:36:08 AM   #1
topspd
Reputation: 0 topspd is on a distinguished road
Default GSP clutch pedal install
Installation of GSP clutch pedal
Disclaimer : This post is merely meant to document my experience with installing this item and I take no responsibility for any damage that may occur from those attempting to duplicate my experience.
Tools required :
- 17mm socket (for locknut on GSP pedal)
- 10mm socket (for removing clutch rebound stop panel)
- 6mm allen key (for bolt on GSP pedal)
- Phillips screwdriver (removing kick panel)
- Trim removal tool (removing kick panel)
- Common slot screwdrivers short and long (removing pin lock and pivot pin)
- Needle nose pliers (for removing/installing spring)
- Vise grip (for bending)
- Flashlight
Remove kick panel :
- Remove three Phillips screws on left hand side
- Remove trim plug on right hand side
- Remove trim plug at back by accelerator pedal by turning
- Pull down around steering column to release two trim clips
- Pull kick panel towards then down to free from dash
- Slide blue lock on OBD connector then push up to free connector
- Unplug 2 plugs in green connector
- Unplug 1 plug in light
- Place kick panel in safe place
Remove stock clutch pedal :
- Use needle nose pliers to pull spring off pedal
- Use short common slot screwdriver to remove pivot pin by inserting between
edge of hole and grey pin and push with significant force while compressing edge of
pin
- Use long common slot screwdriver to pry edge of pin lock clip open then use other hand to slide off pin (notice there is an opening on 1 side of the clip)
- Remove both bolts holding clutch actuator/clutch rebound stop panel closest to seat
- pivot clutch rebound stop panel out of way
- pull clutch pedal towards seat to free end of clutch actuator
- slide pedal off pivot pin
Comparison :
Transfer parts, etc. :
- Remove spring rubber grommet from stock pedal and transfer to GSP pedal
- Remove both sides of pivot pin sleeves from stock pedal and insert into GSP pedal
- Remove rubber cover on stock pedal and put on GSP pedal starting from bottom edge
- Use vise grips to bend clutch rebound stop panel piece that the stock pedal rested against. This piece will interfere with the GSP bolt used instead of the grey locking pin.
Install GSP pedal :
- Slide pedal onto pivot pin
- Move pedal so that it slips over end of clutch actuator
- Insert GSP bolt & locking nut, then tighten completely using allen key on one side and 17mm socket on other
- Reattach clutch rebound stop panel to clutch actuator and tighten bolts
- Use needle nose pliers to put spring on pedal
Install kick panel :
- Attach all 4 previously removed clips
- Slide panel in, watching for plastic guide above dead pedal
- Install 3 screws, 1 turning trim lock by accelerator and 1 push trim lock
Start car, test clutch, go for drive, enjoy!
'04 M3 SilverGrey / Black Cab - Cdn spec, 19", PD: Eisenmann race, HID fogs, Solaris bulbs, Bimmian reflectors, mini antenna, euro plate, aux in, ZHP knob, ZHP shift & brake boots, Dension ice>link+, Green filter, BHS pullies, CSL style diffusor, hardtop, UUC SSK & DSSR, black grills & kidneys, GSP clutch pedal, Halos, CDV free, Stebro S1, Garmin C320, XM radio, Vorsteiner splitters, Volk LE37T Black/polished w/T1R's
Jump to top topspd is offline   Reply With Quote
Old Mon, Oct-31-2005, 05:32:32 AM   #2
Chris S
This is how I roll...
Chris S's Avatar
Reputation: 0 Chris S is on a distinguished road
great write up man!
2008 Alpine/Black e92 M3, 6MT, loaded...
SOLD!!!!!: 2003 Alpine/Imola M3, 2002 996TT White/Natural
Jump to top Chris S is offline   Reply With Quote
Old Mon, Oct-31-2005, 05:46:58 AM   #3
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
nice write up.. how about some pics of the installed product
Old Mon, Oct-31-2005, 08:24:26 PM   #4
xodus
xodus's Avatar
Reputation: 0 xodus is on a distinguished road
Nice write up. How do you like/dislike the clutch pedal?
2004 M3 TiSilver
Jump to top xodus is offline   Reply With Quote
Old Mon, Oct-31-2005, 10:38:06 PM   #5
topspd
Thanks.. the pedal is great, I really recommend it. My driving habit is to always clutch to the floor and with this pedal's reduced throw distance, I find that the car feels faster after a shift as the clutch engages quicker when I release the pedal.
Old Sat, Nov-05-2005, 05:39:18 PM   #6
Ben Liaw
R-O-G-U-E, not ROUGE!
Ben Liaw's Avatar
Reputation: 0 Ben Liaw has disabled reputation
Here's a picture of the one installed in my car...
Jump to top Ben Liaw is offline   Reply With Quote
Old Sat, Nov-05-2005, 06:08:35 PM   #7
BattleWagon
BattleWagon's Avatar
Reputation: 0 BattleWagon is on a distinguished road
...with the stock clutch stop too...
2005 AW 6MT Blk_leather Xenon nothing else SOLD
Jump to top BattleWagon is offline   Reply With Quote
Old Sat, Nov-05-2005, 06:21:53 PM   #8
Ben Liaw
Ben Liaw's Avatar
I don't remember an aftermarket clutch stop working all that well with the GSP pedal, because of that press-to-start clutch switch.
Old Sat, Nov-05-2005, 06:44:50 PM   #9
daytonaviolet
OEM CSL Whoore
thanks ben...
but does anyone have pics of the actual GSP pedals?
Old Sat, Nov-05-2005, 08:12:02 PM   #10
Ben Liaw
Ben Liaw's Avatar
On his site.
www.gsperformance.com
When they were aluminum, Gustave use to include a factory bracket holding the switches, modified (cut) so that you didn't have to bend it as Topspd did in this pic:
Also, you have to transfer the little rubber grommet onto the little hole in the new GSP pedal (windex helps).
Also, when we get them, ZERO directions. Then again, I've gotten the install to about 15 minutes. The BEE-YAAA-CHHH was the pin the first time in this picture:
This pin comes out in 2 seconds, now that I use a very small needle nose plyer to "pinch" the tabs (and the pivot comes shooting out!).
HTH.
clutch, gsp, install, pedal
GSP Clutch Pedal Worth it? sebpop E46 M3 (2001-2006) 4 Thu, Sep-18-2008 09:51:25 PM
WTB: GSP clutch pedal drom Parts for Sale/Wanted 1 Wed, Sep-26-2007 11:07:04 PM
ordered clutch pedal from GSP - install DIY available? ///Malicious E46 M3 (2001-2006) 7 Mon, Aug-20-2007 07:17:32 PM
WTB: GSP clutch pedal NiteRider Parts for Sale/Wanted 2 Mon, Mar-05-2007 08:56:53 PM
FS: GSP Clutch Pedal dut Parts for Sale/Wanted 9 Sun, Jan-22-2006 10:13:56 PM
Discussing GSP clutch pedal install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
