#21 |
Tranny
oem BMW LTF-1 83 229 408 942 Esso/Exxon MTF-LT-1 superceded by LTF-2 Castrol MTF-2 1.7 Lt/3.6 Pt tech specs: fully synthetic gear oil 75W-80 API GL4 MIL-L-2105 another BMW approved is Aral SNS-B SAE 75W80 ATF is too thin, and the Royal Purple gear oil is similar to ATF the Redline MTL is rated 75W80/GL4, so it meets the spec http://www.redlineoil.com/whitePaper/13.pdf Diff BMW 83 221 470 080 (large container)/83 221 467 993(small) special gear oil oem Castrol SAF-XJ 75W-140 1.2 Lt/2.6 Pt API 75W140 GL5+LS this is a special, fully synthetic 75W-140 gear oil with special additives for the locking limited slip, oil without these modifiers would not be appropriate and should NOT be used the only other oil I could find approved by BMW is Aral BS-LSX SAE 75W140 |
#22 |
![]() Location: San Diego, CA
So Art, which would you recommend from the Redline series?
#23 | |
and the oem in the diff, but if I could find a fully synthetic 75W/140 GL5+ I would use it...it's the spec, and in Europe I believe there are others, Aral for one, that are spec'ed... Valvoline makes a fully synthetic 75W/140 GL5+ (w/LS designation, iirc that's what the + means) that I THINK is approved in europe by BMW... |
#24 |
So I guess for the mantrans I should be using either:
http://www.turnermotorsport.com/html...RODUCT_ID=MT90 or http://www.turnermotorsport.com/html...PRODUCT_ID=MTL And for the Diff Oil, the OEM oil with FM booster... or the redline version: http://www.turnermotorsport.com/html...DUCT_ID=75/140 they also seem to sell a 75/90 with FM http://www.turnermotorsport.com/html...ODUCT_ID=75/90 |
#25 | |
Redline diff oil is ok..
But, for D4-ATF, it is NOT good for a Getrag 6 speed transmission.. It was nothing short of the worst nightmare one can possibly have... Go ask supra tt owners about how many Getrag 6spds did D4-ATF kill.. It was a major disaster, the symptom was anywhere from (minor) cold centering problem to (major) total tranny replacement. Damn Redline actually recommended ATF-D4 for supra tt 6spds at the time.. When the problem occurred, they refused to acknowledge ever recommending ATF-D4... and of course, refuse to pay any kind of damage they caused.. F them.... i'd say stick with OEM stuff,,, redline stuff is not an upgrade, they are a marketing company that knows how to promote their stuff.. -jjc. former Supra TT 6spds owner (victim) Quote:
#26 |
Straight from Turner Motorsports
http://www.turnermotorsport.com/html...ODUCT_ID=ATFD4 Red Line Synthetic D4 ATF Synthetic D4 ATF is suitable for use where Dexron III, Dexron II, or Mercon fluids are recommended. BMW recommends ATF oil in all manual transmission in cars produced 1/1995 and later. The D4 ATF provides significantly improved gear protection. The balanced frictional characteristics provides smooth and consistent shifts for extended drain intervals. The superior stability compared to petroleum ATFs allows high-temperature operation without varnishing valves and clutches which leads to transmission failure. |
#27 |
I have also been suggested to run D4-ATF (which I have on order) and 75W90 No Slip
My question is what's hte difference between 75W90NS and 75W90??? One doesn't contain the friction modifiers for limited-slip hypoid diffs... what does that mean for us M3 owners??? Charles |
#28 | |
it's NOT recommended for the e46 M3, I gave the specs above, gear oil 75W/80 GL4...my e36 M3 used ATF...the car will have a sticker on it...the e46 M3 does NOT... the rear takes 75W140, 75W90 is too light the NS is for locking diffs, not limited slip, iirc...don't use this... I have the BMW documents for the tranny and diff, they are PDF files...I'll email to someone who'll post them Last edited by ArtM3; Sat, Nov-05-2005 at 09:15:25 PM. |
#29 |
Zack Steinkamp
i'm going to ask my mechanic about the D4-ATF tomorrow. he's also an instructor at the infineon school.
the nobot dot org |
#30 | ||
Baby got back
![]() Location: Frisco, TX
EDIT: Just saw your comments on the GL-5+LS flavor. Redline has 75w-140 and 75w-140NS -- I'm thinking the 75w-140 would satisfy the the GL-5+LS flavor. ///Michael.
1995 M3 Coupe 2004 911 Carrera 4S Last edited by Michael-Dallas; Sun, Nov-06-2005 at 05:20:15 PM. |
| changed, diff, fluid, impressions, redline, tranny |
| Just had the tranny fluid changed and CDV taken off. | fastfed | E46 M3 (2001-2006) | 43 | Tue, Mar-31-2009 08:53:27 PM |
| SMG Tranny Fluid & Diff Fluid - Change Interval? | Nominee | Faults, Fixes and DIY | 3 | Fri, Nov-02-2007 08:25:34 AM |
| Just changed diff fluid... | m3car | E46 M3 (2001-2006) | 2 | Wed, Jul-26-2006 06:00:21 AM |
| Changed fluid, tranny shifts like CRAP! | Skyman | E46 M3 (2001-2006) | 18 | Tue, Mar-28-2006 03:17:24 AM |
| Anyone changed the Tranny fluid to Redline or Royal Purple? | Rob's Archive | E46 M3 (2001-2006) | 26 | Tue, Jul-15-2003 11:25:48 PM |
