Anon
![]() Location: Fairfield County
My clutch pedal has completley disconected from the master cylinder. From what I could tell there is a black plastic loop on the end of the piston for the master cylinder. Upon further inspection I found the plactic loop (connector to clutch pedal) in two pecies on the floor. CRAP! I'm considering replacing the master cylinder and the bushings for the clutch pedal to prevent future issues.
What I was hoping for was a write up on performing this replacement. Thanks in advance! -Jason Here is a pic. It may not be the exact part but it's close. The circled part is what broke off. Help! Please! ![]()
2004 BMW M3 6MT | 2002 Audi A6 3.0 http://twitter.com/#!/ShreddieMurphy Gone but not forgotten... 1997 BMW M3 1993 BMW 325is 1992 BMW 325i |
#2 | |
Team Nexen Racing
i havent done it on an e36.. but yes you should replace the master. but just did one on another car.
in general. uncock the bleeder on the slave.. allow to drain. disconnect the linkage from the pedal (you can skip this step) disconnect the hard line from the master itself, under the hood. unbolt the master from the firewall and pull it out (from under the hood) install is the reverse.. then bleed the hell out of it. sometimes its best to bench bleed the cylinder before it goes in the car.. that helps to get some air out.
![]() Current - '99 estoril/mulberry coupe || Past - '97 alpine/anthrazit coupe || 10,000+ post club || OG club Quote:
#3 | |
The only answer is to replace the cylinder. I found one by doing a web-search for about $45 (forget from who - but that was at least $30 less than from BMW - and it was IDENTICAL..) and I had it in 2 days. It isn't that awful a job to replace. It turns out the lines leading to it - on later model M3's - fasten to it on the inside of the firewall with a sort of snap-in connector. When you get the new cylinder you'll see what I mean. Older designs used connections on the engine side of the firewall that look like a real pain to get to and replace. It took me about 1 hour to do - but I knew exactly what I had to do since I'd been in there before looking at how to do it. When you're done - it pretty much bleeds itself since the input line to it from the brake-cylinder fluid reservoir is in a straight line - and the air bubbles up and the fluid trickles down into it. As you mentioned - this would be a good time to also do the clutch pedal bushings (which I also did.. UUC's)
#4 |
Anon
Guys thanks big time. I'll update with the results in a few days. Thanks again.
#5 | ||||
| Clutch master cylinder replacement | djungel-Jim | E36 M3 (1992-1999) | 3 | Tue, Jul-22-2008 12:25:52 PM |
| Clutch master cylinder | phantom3 | E36 M3 (1992-1999) | 7 | Sat, Jul-14-2007 02:18:46 PM |
| Leaking clutch master cylinder | virsipe | E46 M3 (2001-2006) | 2 | Mon, Feb-05-2007 08:08:36 PM |
| Clutch Master / Slave cylinder | agapehme | E36 M3 (1992-1999) | 2 | Mon, Jun-02-2003 08:51:37 PM |
